Reply 40 of 130, by ElTentakel
onethirdxcubed wrote on 2026-01-22, 23:32:I thought Windows 9x didn't support the IOAPIC at all and so was limited to IRQ 0-15?
That's the impression I got from this article at least.
It's also possible that it does do utilize the APIC but only when installed in ACPI mode which I have also had considerable trouble with on modern hardware. QuickInstall always deposits a system image set for non ACPI mode but it might rerun the hardware detection and enable ACPI if the install is moved to another system.
I can definitely negate this. The Device Manager sais that APM 1.2 is installed on the MSI B85M-E45, but is has a yellow exclamation mark because of missing drivers.
