Reply 40 of 43, by Disruptor
You all do the spelling error.
It is SiI, not Sil or SiL. Double i like sii (silicon image)
And, yes. I also have problems in my 486.
SATA 120 GB disk:
DOS = no problem
Windows 9x = problem not solved yet
Windows 2000 = no problem
Base BIOS for SiI 3114
Reply 41 of 43, by shevalier
Repo Man11 wrote on 2026-07-16, 21:37:
I removed the SiL card and used a Startech SATA to IDE adapter instead and reinstalled Windows
Ultimately, I, too, arrived at this very method as the simplest one.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 42 of 43, by rwGast
Well i have a startech arriving today and some other unkown converters I got off ebay. I tried to install XP, just as a test, but you cant run setup from the dos prompt. I was going to try to install xp using plop, but the adapters will be here and I didnt get the time.
The souncard issue is wild! I am using a dell mobo with built in sound, i have no idea what sound chipset it is (have had bigger concerns, like getting w98 to install), but i bet it is pci! I dont think i can disable it in the bios though 😒. I really hate oem mobo bios'es.
Reply 43 of 43, by PcBytes
rwGast wrote on Yesterday, 13:27:
Up to Longhorn you can run setup via DOS prompt. Boot off a 98SE medium (boot disk or CD), navigate to i386 folder and use winnt /b.
