Runtime error 002 at 0004:2C46.
Reply 40 of 43, by Gwenhwyfar
It runs now 😀 But now I have no water at all, even not there, where it should be
EDIT: I was wrong... There isn't no water at all, its just at the very bottom end of the screen.
Reply 41 of 43, by vasyl
I see. In addition to that patch, this game is also timing sensitive. Try starting it with different cycle counts. For me, it works well with 6000 cycles.
Reply 42 of 43, by Gwenhwyfar
I tried 6000, was a little to much. For me it runs perfectly with 5600! 😁
I can't believe that I can run this game. Thank you all so much, I would never have done this without you... I think I will play kelloggs for the whole day now! ^^
Reply 43 of 43, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Game doesn't accept input at the main menu in 0.65 and 0.70. Works in 0.63.
The "Start-Button" should blink continually but only does once.
Tried the dyn/normal/full and loadfix.
1+1=10
