DOSBox Game Launcher (DOSBox Frontend)
Reply 40 of 2211, by rcblanke
@Bouchacha: Thanks you for your compliments! About the 8.3 issue you mentioned; it should be working. Can you give me an example to reproduce the problem?! Thanks!
To run the setup for a given profile, just press shift-enter (as in D-Fend). By the way, ctrl-enter brings up the profile-editing screen.
Regards,
Ronald
Reply 41 of 2211, by Bouchacha
Before I get to that, I found a bug.
It seems like if you include a mount command in the default dosbox.conf under autoexec, when you go to add a new template under DBGL, the frontend scans dosbox.conf and crashes.
The following message is left:
C:\Games\DOS Games\dbgl031>java -Djava.library.path=lib -jar dbgl.jar
startup
Could not read settings.conf
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
at java.lang.String.substring(Unknown Source)
at com.model.Mount.<init>(Mount.java:59)
at com.model.Autoexec.<init>(Autoexec.java:72)
at com.gui.EditTemplateDialog.selectSettingsByAutoexec(EditTemplateDialog.java:916)
at com.gui.EditTemplateDialog.selectSettingsByConfiguration(EditTemplateDialog.java:992)
at com.gui.EditTemplateDialog.createContents(EditTemplateDialog.java:904)
at com.gui.EditTemplateDialog.open(EditTemplateDialog.java:146)
at com.gui.MainWindow.doAddTemplate(MainWindow.java:686)
at com.gui.MainWindow.access$14(MainWindow.java:679)
at com.gui.MainWindow$37.widgetSelected(MainWindow.java:538)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:90)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2968)
at com.gui.MainWindow.open(MainWindow.java:117)
at com.gui.MainWindow.main(MainWindow.java:98)
Edit: Problem is non-existent if you include:
mount c "c:\games\dosgam~1\" -t dir
instead of what the dosbox wiki tells you to put:
mount C C:\games\dosgam~1
C:
Double edit:
For some strange reason, the mounting commands are listed normal when you make a new template but when you go back to edit the template or make a new profile, it's listed twice:
No matter how many times you delete that double entry from the template itself through the front-end, it never goes away. When you make a new profile based on that template and go back to edit it, you'll see it listed 3 times!
Triple Edit: Nevermind, I figured it out. Since DBGL only makes amends to the conf file instead of actually editing it, the autoexec command gets used twice. It shouldn't cause any problems but you might want to address it.
Agree with us on everything
or we won't help with anything
that kind of attitude
just makes a split grow wider
Reply 42 of 2211, by Bouchacha
As for the other thing, since I didn't have any D-Fend profiles saved, I had to create new ones. I click on Add Profile and since I don't need to make any changes to the settings I go directly to Mounting. This is where I specify where the game actually is. I click browse and point the program to the right location. After I title it properly and click OK, I get this:
Everything works just fine if I change the pathnames to conform to good old 8.3 dos naming:
C:\Games\DOSGam~1\Betray~1\KRONDOR.EXE
However, it is rather annoying have to count 6 characters and manually including the squiggly 1 after each folder. Is there anyway for the field or for the program to automatically translate it into a language dos understands?
Also, the timesynched feature is missing from the Machine>Cpu section
Sorry if I'm including too much. I hope this helps. Please keep up the great work, I know I'm going to continue using this!
Reply 43 of 2211, by rcblanke
I don't understand why you're using 8.3 syntax for your mount-point? AFAIK, it is perfectly legal to use full pathname notation. So why not change that?
The timesynced feature will be added! Hey, you're using DBGL, and I really appreciate the feedback!
Regards,
Ronald
Reply 44 of 2211, by Bouchacha
I tried! I click browse under the mounting tab to find the file I want to direct to. That gives me the full pathname automatically. However, when I click OK to save the profile, it gives me the message noted in the screenshot. It's only until I change the pathname under Execute>DOS>Main to 8.3 syntax that the program finally cooperates. I wish I didn't have to but it doesn't let me otherwise.
Reply 45 of 2211, by rcblanke
No, not with the file, in the upper part of the screen; Use full path syntax for your _mount_ command. Works for me!?
Reply 46 of 2211, by rcblanke
Just uploaded v0.4 for Linux! Requires JRE1.5, have fun people!
Windows v0.4 will be uploaded tomorrow.
Reply 47 of 2211, by Bouchacha
I see, that's what I tried the first time but DOSBox doesn't understand the commands. I seem to recall from looking at D-Fend custom config files that it automatically parsed pathnames to 8.3 syntax in order to work with DosBox.
Thank you again for your help and for such a wonderful program. Eagerly anticipating the development.
Reply 48 of 2211, by Qbix
Rank DOSBox Author
DOSBox Author
the directory name contains spaces and is longer then the 8.3
Futher timesynced is not an offcial option
Water flows down the stream
Reply 49 of 2211, by Bouchacha
Hello Qbix. I know the directory name contains spaces. I was wondering if DBGL can automatically parse the pathname to conform to 8.3 syntax just like D-Fend (I believe) does. It would make creating new profiles MUCH easier.
Reply 50 of 2211, by rcblanke
Hi everybody,
The update for DBGL version 0.4 is available. Fixed a couple of bugs, but most importantly, it is now multiplatform. The Linux build was tested on Ubuntu Dapper Drake only, so please, if you're running on another distro let me know how it goes!
Regards,
Ronald
Sorry, I understand the problem now. Will fix it for the upcoming release.
About timesynched; This setting will only be stored in the profiles' .conf file when the underlying dosbox.conf contains the setting (like ykhwong's). In effect, the profiles' .conf file will never be cluttered with 'timesynched=false' when using plain v0.65, for example.
Reply 51 of 2211, by Qbix
Rank DOSBox Author
DOSBox Author
Maybe it is an error from my side:
If I select a executable ( add profile/mouting) /tmp/arj.exe
and I press "ok" then I get a warning no mountpoint selected.
DOSBox itself Is capable of running games like this (dosbox /tmp/arj.exe)
Maybe you can create something like this. (some sort of automatic mount point ?)
Reply 52 of 2211, by rcblanke
Qbix wrote:
Maybe it is an error from my side: If I select a executable ( add profile/mouting) /tmp/arj.exe and I press "ok" then I get a wa […]
Good idea, shouldn't be too hard to do.. You can expect it in the upcoming release!
BTW, how does DBGL behave on your distro? Mmm, you're runing Debian right? Do the popup windows look ok to you?
Reply 53 of 2211, by Spearhead
had a quick look under Gentoo, the windows seem to look alright, the only thing i changed was in the dbgl file, i simply put "java" as executing command without the path, because the location is different at Gentoo (standard is /usr/bin/java). No biggie though, i would include a small readme though for that ^^
(easy way of determining java executable location is to input "which java" in the console" 😀 )
Reply 54 of 2211, by rcblanke
Thank you Spearhead, your feedback is greatly appreciated, aspecially as it looks like not too many people are testing my frontend on Linux, yet.
Regards,
Ronald
Reply 55 of 2211, by Spearhead
No problem, i appreciate that you took the time to make the Linux version 😉
Reply 56 of 2211, by DosFreak
Regards,
Ronald
heh. Not much for frontends and haven't had time for testing this month. 🙁
Make your games work offline
Reply 57 of 2211, by rcblanke
Hey, no offence intended DosFreak 😀 It's just that I hadn't expected the download figures to be as much different as they are now (win:55+ vs. linux:4)
Reply 58 of 2211, by DosFreak
Yeah, it would be nice to know what the statistics are for DosBox usage. Just pretty much anything tho it'll be far more Windows users than Linux users. 🙁
I should be free this weekend and I'll definetly be testing it out in Linux.....of course that's what I said earlier this week about testing Fallout\Daggerfall in a thread I posted 2 weeks ago.... 😉
Reply 59 of 2211, by Bouchacha
wait what? Fallout runs under DOSBox?
e: I forgot there was a dos version
