Help with dosbox on vista
Reply 40 of 43, by BakNBlack
Pat,
I had the same issue with the 'negativised' image on Full-Screen mode (either switching to or startingn as), I solved it by setting output to overlay instead of surface mode.
Reply 41 of 43, by Logan Felipe
Hello.
I tried entering a command in the latest version of dosbox on my vista laptop, but was unable to finish the command. When I pressed the "\" key, "]" appeared. This only happens in dosbox. Can this be fixed in dosbox, or is it a hardware issue?
Thanks,
Logan
Reply 42 of 43, by wd
Rank DOSBox Author
DOSBox Author
What keyboard layout does your OS have?
Reply 43 of 43, by Logan Felipe
Just realized what the Dosbox keymapper is for...
I was able to reassign the keys with the Dosbox keymapper.
BTW; it was an HP Laptop with QWERTY and the delete button above the backspace button.
Hope this helps others with this problem...
Thanks for your reply though. : )
