Reply 40 of 50, by thierry
SPACE ACE ITS COMING !!!!!!
Reply 41 of 50, by thierry
and HERE IT IS !!!!!
THANKS TO htcmeme , grateful to share the ISO
Link :
LINK REMOVED
<no links to abandonware / warez>
initially had trouble with the game, I lost it hung, and not working demos, it comes with 3 demos (there are videos)
Dragons Lair 1 , Dragons Lair 2 and BrainDead13 , but im free memory in the autoexec.bat and config.sys and now works
perfect!
Reply 42 of 50, by thierry
Thanks again to stuvize , send me a PM to another ISO ,
It is larger, about 80 megs, I think we should try if an update is that there is an update to the Dragons Lair because it has many bugs, I will investigate
I'm updating the link, I'm up to MU
Change the google drive link and download to all
Reply 43 of 50, by swaaye
I've removed the download link. You are not allowed to post links to abandonware on VOGONS.
Reply 44 of 50, by thierry
PM and im send the link to all
Reply 45 of 50, by dr.zeissler
did not get it 🙁
Reply 46 of 50, by thierry
dr.zeissler wrote:
did not get it 🙁
PM Send!
Reply 47 of 50, by thierry
Tip : Copy all to HD ( space ace ) and play it from Hard Disk
Reply 48 of 50, by Roman78
Huge Topic Kick....
Yesterday I tried to run Dragons Lair and The Horde on my Pentium II whit a Real Magic Card. Unfortunately I own the EM8300 PCI card and not the ISA card. So I was unable play the games.
Dragons Liar started to a selection screen were I could select language, FPS and some other settings, than it gave a huge unreadable error.
The Horde gave the error message that RMDEV.SYS is not loaded.
Got some drivers for the ISA card (including that RMDEV.SYS) that won't work on the PCI card, and the PCI card drivers won't work whit the Games/Dos.
I think that the PCI card is mostly to watch DVD's on your Pentium 1 system. But than I tried to Watch a DVD on Windows 98 using the Real magic card, but that also did not worked as expected. Could it be that it only working with the loop-trough-cable? I simply connected a Second monitor on the Monitor output of the Real Magic card.
Reply 49 of 50, by uVSthem
I'm a bit late to this conversation, but I believe a 1.1 update patch was released for the ReelMagic version of The Horde, just like there was for the standard CD-ROM and floppy disk versions. Does anyone have this 1.1 patch for the ReelMagic version?
Reply 50 of 50, by Uka
Yes, there was a patch 1.1 - but I was not able to find it, probably it has not been preserved unfortunately.
