Reply 40 of 2283, by Alexander
I have just finished the multiple image option. In D-Fend Reloaded 0.2 you will be able to define multiple CD images and multiple floppy images when booting from floppy.
To avoid the 134 chars problem the directories/files for all mount/imgmount commands are now transfered to short names ("Program files" -> "PROGRA~1") when building the DOSBox conf files. If you use multiple images for one mount and all image file are in the same directory, D-Fend Reloaded will look for the last unused drive letter (normally "Y:"), temporary mount the images directory as Y:, imgmount's the images and then unmounts Y:, thank you Qbix. (... without having to setup anything for this manually.)
(And of course thank you IIGS_User for your hint, but I prefer to have all config settings in the DosBox conf file.)
All things I wanted to have in the 0.2 release are now ready. In the next days I will build some installers (not only complete installer like now but also an update installer which will only contain the changed files).
@Neville: I have attached the new spanish language file. If you like to translate the new strings, I would be glad. Altogether there are 38 new strings. Additionally I have made a list of all untranslated strings (also included in the zip) so you don't need to search for them.
I hope to find enough time the next days to finish version 0.2 so you can play with it this weekend.
