Reply 40 of 55, by cdoublejj
- Oldbie
i have 3 of these big drives 2 untested i found on the free table and 1 combo drive but, you can only use 1 of the 2 drives at once and switching requires changing the cable. i took the face plate of and painted it black to match my case. but, since my sd card reader's floppy needs a floppy cable i ditched the 5 incher. now if i found an sd/floppy combo with a usb floppy too i'd get single 5 incher and paint it black too and put it in assuming i could get one with out the lever as my case has a door. i had the idea of switching the green led for a blue one to match my case even more.
