Reply 40 of 42, by d1stortion
Onboard Realtek junk. Well, considering it's a pure software solution I'm not sure if the sound hardware has something to do with it...
Reply 41 of 42, by Stojke
Mighty be, I'm no expert 😀
I can only guess because i don't know what are you using to achieve playback.
Also, after testing TMIDI out a bit with VMS it appears to be very responsive. Plays MIDIs instantly with no delay nor skipping/clipping. Also song time position changing is very fast and responsive too.
Reply 42 of 42, by rfnagel
Stojke wrote:
Also i can upload it for you, 222MB SFPacked.
Many thanks! 😀 Simply PM me with the link (or link it here in this thread), and thanks again 😀
d1stortion wrote:
Hey, I recently tested out your soundfont with BASSMIDI. Really nice.
Glad you liked my (not so)humble SoundFont creation 😀
d1stortion wrote:
I even made a recording of it here which showcases its strong parts quite well imo: http://www.youtube.com/watch?v=kqaG0YDZvEo
Sounds good 😀
d1stortion wrote:
But I have one gripe about it. It seems like when an instrument plays for the first time the samples have to be loaded with a slight delay and popping noise, so the MIDI needs to be played two times to listen to it properly. Do you know anything about that problem?
You might try adjusting the buffer sliders on the "Advanced" tab of the BASSMIDI Driver Utility. That being said, you might post a message here -> http://www.hydrogenaudio.org/forums/index.php … showtopic=87639 ... that's the message thread that the authors of the BASSMIDI Driver ("MudLord" and "Kode54") frequent 😀
Rich ¥Weeds¥ Nagel
http://www.richnagel.net
