Reply 40 of 41, by Robin4
- l33t
wrote:wrote:I have also in the time i wasnt present here found an second Juko V20 motherboard, luckily it came with the original manual and a 5.25 floppy driver disk..
Do you mind uploading the manual and the disk?
Yah i will do later. Because i dont have checked if the floppy was working.. So this is the first thing i would do.. Maybe its a good idea to do a diskcopy first. This will happen if the XT clone system will be together and make it accesable for using the older floppy drive.. Scanning the manual will be a little bit harder..
I can try to make a one fly photo with my smartphone..
