Reply 40 of 41, by Qbix
Qbix
Offline
DOSBox Author
- DOSBox Author
yes. you must see where it installs it user handler.
(it probably does)
break on int 33 0c or 13
if it doesn't install one just break on every int 33 call
if you know where the userhandler is change your code display to it and
put breakpoints in it
Water flows down the stream
