DOSBox has stopped working and closes at startup.
Reply 40 of 111, by Tanukitsune
Success! Disabled all sounds made it work! Now I have to figure out how to get it to work with the sound.
Reply 41 of 111, by truth_deleted
Try setting SDL_AUDIODRIVER to waveout. (also may help to reinstall the audio driver in Windows)
Reply 42 of 111, by Tanukitsune
When I set the audiodriver to waveout it says " MIXER: Got different values from SDL: Freq 44100, blocksize 11028". and crashes.. I'm trying to find out which driver I need to try to reinstall.
Reply 44 of 111, by Qbix
Rank DOSBox Author
DOSBox Author
maybe set nosound=true on the configuration file. to see if that solves the crashing.
(and set mpu401=none as well)
Water flows down the stream
Reply 45 of 111, by Tanukitsune
collector wrote:
I notice that you have an Audigy. What drivers do you have installed? Are you using a 3rd party ASIO driver?
Oops, I didn't even notice my sig was my old PC rig.... I have Realtek one now. 😊
Nope, that didn't do anything, but something has changed because now when it crashes, I can't really see the status window, when I move it the part that was under the DOSBox window is just a white block.
Reply 47 of 111, by Tanukitsune
Unfortunately, it's still and empty file.
Reply 48 of 111, by Qbix
Rank DOSBox Author
DOSBox Author
what does the eventlog say now ?
Reply 49 of 111, by Tanukitsune
Nombre de la aplicación con errores: DOSBox.exe, versión: 0.74.0.0, marca de tiempo: 0x4bea7d36
Nombre del módulo con errores: wdmaud.drv, versión: 6.1.7601.17514, marca de tiempo: 0x4ce7ba26
Código de excepción: 0xc0000005
Desplazamiento de errores: 0x00016705
Id. del proceso con errores: 0xc3c
Hora de inicio de la aplicación con errores: 0x01cef748e45e9ced
Ruta de acceso de la aplicación con errores: C:\Program Files (x86)\DOSBox-0.74\DOSBox.exe
Ruta de acceso del módulo con errores: C:\Windows\system32\wdmaud.drv
Id. del informe: 23fd71d2-633c-11e3-a804-14dae92eb5a7
It seems to be the same error as before.
Reply 51 of 111, by Tanukitsune
I did that yesterday. 😐
Reply 52 of 111, by Joey_sw
in windows device manager, what driver/devices that listed that might be related to audio ?
-fffuuu
Reply 53 of 111, by Tanukitsune
Something called High Definition Driver (hdaudbud.sys) and something called High Definition Audio Device, which I assume is my Realtek audio device?
Reply 54 of 111, by Jorpho
Are you running anything else in the background that might be trying to use your audio device? Some sort of VOIP application, for instance?
Reply 55 of 111, by Tanukitsune
I don't have any VOIP programs, just in case, I closed most of my programs except my antivirus, which I already tried before, it still didn't work.
Reply 57 of 111, by Tanukitsune
I only have Win 7 and and one device, and I have to disable all related to it, even if it's not in use, like S/PDIF, to get DOSBox to work.
Reply 58 of 111, by NY00123
Tested any other SDL 1.2 application by chance?
Reply 59 of 111, by Tanukitsune
I'm not sure, it's seems I have SLD 2.0 games according to the SDL site, but I can't find any information on anything made with SDL 1.2.
