M396F motherboard
Reply 42 of 61, by Anonymous Coward
Some chipsets contain a very small amount of internal cache for low cost systems. On the MX chipset, 8kb. On the SiS Rabbit chipset, there is a miniscule 128byte cache of some sort. I assume this makes a difference. Not sure about the SARC chipset though.
Reply 44 of 61, by Anonymous Coward
Who knows. It's hard enough trying to get information for the mainstream chipsets, much less the smaller guys. SARC seems decent, but usually found on low end 386 and 486 boards.
Reply 45 of 61, by kixs
A couple of days ago I bought the same board with 486slc-33, rev. 2.6. It came today 😁
I quickly set it up and done some benchmarks. But to my surprise it was a bit slower then I expected - I used to have 486slc-33 back in the days and still have banchmarks of it - PMIPS to be precise.
Well, what can you do... 😒
I did all the standard benchmarks and then something interesting, yet unexplained happened, it begun to run faster, but only until reboot 😕
Setup configuration:
486SLC-33MHz, 1KB cache enabled
16MB 70ns
CL-5429 2MB ISA
HDD Controller ISA
These are results with a clean boot:
3dbench 1.0c... 11.6
PCPlayer... 2.8
DOOM... 15994
Checkit... 5666
Speedsys... CPU: 13.91, MEM avg: 7.74
Vspeed... 2.95
PMIPS... 8.2
Cachechk... 1: 45, 2...16: 127
F1GP... 258%
Sysinfo... 54.3
And these are results when it runs faster:
3dbench 1.0c... 15.8
PCPlayer... 4.0
DOOM... 10851
Checkit... 9337
Speedsys... CPU: 16.81, MEM avg: 17.25MB/s
Vspeed... 3.32
PMIPS... 9.3
Cachechk... 1: 41, 2...16: 64
F1GP... 184%
Sysinfo... 54.3
This latter results are what they should be in the first place.
After digging what actually made it run faster... it was only after I run SYSINFO. I guess I'll add sysinfo /tsr in autoexec.bat
This board has jumpers for 33/40MHz operation but it isn't stable at 40 even with additional cooling. At 40MHz it runs a bit faster then 386DX-40 - 3DBench is 18.1
I also did the benchmarks with 1KB cache disabled and they are relly low. Without SYSINFO it runs like a 286-10MHz and with SYSINFO it runs like 386SX-25.
I wish BIOS had more advanced options.
And what does SYSINFO actually do to make it run like it is supposed to?
Pictures:
Ahpterp.jpg?1
Visit my AmiBay items for sale (updated: 2025-03-14). I also take requests 😉
Reply 46 of 61, by PhilsComputerLab
🤣 that's very odd.
YouTube, Facebook, Website
Reply 47 of 61, by kixs
Yes, to say the least 😲
And there are no BIOS options nor jumpers... just the SYSINFO that does the trick 😒
Reply 48 of 61, by kixs
I tinkered a bit with this board again... and it seems all it needs is a jumper on the turbo switch (as many boards do but the difference between ON/OFF with this one is minimal, so it wasn't that obvious). But it's still weird that sysinfo would somehow turn the turbo on.
Also tried to run it at 40Mhz again. It works fine with 60ns simms and additional cooling of the CPU - it gets really hot.
At 33MHz with turbo on it's exactly the same speed as my 486slc-33 from Acer back in 1993. Nice flash back 😀
Reply 49 of 61, by PhilsComputerLab
I always love reading about this board. I like it a lot, it's so minimalistic and really reliable too.
Reply 50 of 61, by 386_junkie
Mau1wurf1977 wrote:
Ok took screenshots for both systems: […]
386DX-40 system with UMC chipset and 256KB cache disabled:
CruG2qVh.png]
Which benchmark program is this?
Reply 51 of 61, by PhilsComputerLab
That's Norton System Information. It's included in this benchmark pack with lots of others if you want to check it out: http://www.philscomputerlab.com/dos-benchmark-pack.html
Reply 53 of 61, by Anonymous Coward
It might be okay. 1992 is kind of borderline for overclocking potential. Why not just get a usli or iit 40mhz part, or a 33mhz Cyril fasmath?
http://m.ebay.com/itm/Coprozessor-80387-33-MH … a%257Ciid%253A2
Reply 54 of 61, by SilverGreen93
I searched only of 80387SX and found the 25MHz version. Didn't know there were others. I see if I can get it cheap in the auction. The IIT seems more expensive that I can afford right now for a hobby. But I will keep an eye on them, thanks. So it means that I have to match the frequency of the CPU.
Reply 55 of 61, by Anonymous Coward
You don't need to match the speed, but it should be at least as fast as the cpu, unless you run the fpu in Async mode(intel only) which is much slower. Btw, for 386 generation Cyrix fpus are fastest.
Reply 56 of 61, by Eep386
Sorry to bump this thread, but I managed to score one of these from the recycler with a Cyrix Cx486SLC/2-50 processor onboard. Amazingly, even though it fell off a forklift onto the ground, it still boots and runs.
With the turbo on, it feels rather nice for having no L2 cache, definitely like what I'd expect a 386SX-33 to feel like. It came with an Oak OTI-067 VGA card, which originally had 256K but I added an additional 256K to boost it to 512K; despite this, my Trident 8900CL ISA card is definitely faster on it.
Reply 57 of 61, by Nvm1
I also own this board with a ti486SXL2-50 on board. The board doesn't post because of substantial damage to the area around the battery.
Is it possible to make some detailed pictures of this area and upload them here? Then I can try to figure out which paths need repair 😐
Reply 58 of 61, by Anonymous Coward
This board would be pretty slick with the SXLC2. I used to own this board, and was planning to swap the 386SX-40 for an SXLC-40, but sold the board before I got around to it.
Reply 59 of 61, by jafir
Mau1wurf1977 wrote:
Motherboard on Stason.org: http://stason.org/TULARC/pc/motherboards/F/FO … ml#.UpPYwcQSbzY
And I found a PDF version and attached it to this message!
On my motherboard the jumpers for clock speed are hard-wired or don't exist. Might be a newer revision with the jumpers.
I found another version of that manual, almost identical, except that the cover page lists 486SLC and the last page lists info about jumper that disabled the battery during shipping.
