Reply 40 of 121, by PeterLI
wrote:Of course. In case you have the skill / tools you could always look into building / designing a MIF-IPC-A PCI clone. A MCA version would be even cooler.
Unfortunately i don't have that kind of talent. But would be definitely very cool.
I think because PCI has no DMA controller it could be difficult to make a card that was designed for the ISA bus to work on a PCI bus. There are ways to go around it added by proper chipset support also.
wrote:Right. But that is exactly why it becomes problematic: it is not very straightforward like ISA and a MIF-IPC-A which has very few components really.
Did you ask him about PCI?
Nicely efficient! Would a special bracket be required for the DB-25?
wrote:Any regular DB25 25PIN serial cable will work. So that is convenient as well. 😀
The connection between the MIF and MPU is essentially a bus extension. Use a low-quality cable, or one longer than three feet, and you're asking for trouble. Ask Great Hierophant about his recent experience. 😀
wrote:What happened GH? 😀
I used a 12' cable, and it seemed to work fine at first. On slower systems it gave me weird errors like MPU INIT ERROR on the MT-32's display, which I had never seen before.
wrote:Interesting. Shorter cables might be the better choice then.
The official cable is 42" long, end to end.
Congratulations on the compact design, I look forward to trying a board out.
Awesome!! Waiting for results!
With all those switch options, its better than the original.
