Alrighty guys.. I think I need some additional clarification on these Pro Patches Lite packages. I downloaded the 1.60 and 1.61 upgrade zips, and ran through the instructions bundled inside.
Here's what I did:
* Installed the full 4.11 GUS driver package to C:\DRIVERS\GUS and I can see the default patches in the \MIDI subdirectory
* Card is working fine at 240,7,7,7,7 - outputting from the GUS Classic to the line-input of my SB16 (Non-PNP)
* Extracted the Pro Patches Lite 1.60 files into a directory -> C:\DRIVERS\GUS\PATCHES
* Added "SET PROPATS=C:\DRIVERS\GUS\PATCHES" to my AutoExec.bat and rebooted
* Ran C:\DRIVERS\GUS\PATCHES\Install.exe and got a bunch of "bad command or file name" lines, but it did do a bunch of processing on some patches
Is this right so far? If not, please instruct me. If so, how do I get the 1.61 patch to apply?
Secondly, I did copy the DOOM1 and DOOM2 .WAD files and am loading each with the following command lines:
DOOM.exe -FILE GUS1M.WAD
DOOM2.exe -FILE GUS1MIID.WAD
But the music sounds the same to me, regardless of whether or not I use the .WAD?
