MechWarrior 2 Version 1.1 now works in DOSBox.
Reply 40 of 71, by garcy
sorry this is gonno sound dumb but how do u mount a image file. I have a .cue and a .bin file. I know what they both do but i dont know how u would mount them. i tryed it in dosbox
any help would be really helpful
Thanks,
Garcy
Reply 41 of 71, by emodel
load the image in Deamon tools, and mount -daemon tools created- cd drive within dosbox
Reply 42 of 71, by rcblanke
..or use something like
imgmount d: image.cue -t iso
Reply 43 of 71, by garcy
oh cheers, but i still have a problem, ok ill start from the start.
I have the DOS ver 1.1 of mechwarrior 2 i install it mounting c drive and d. everything runs normal except for a few errors but people have said just ignore them. anyway i applyed the no-cd patch it runes fine but when i go into Netmech dos it says "[lease insert the Mechwarrior 2 cd-rom" now i downloaded a .cue and .bin files. My quess is that i have a different version bin file that the cd i have. ok my question is how mound i go about making a .bin file i know how to make i .cue file i just need to know abount the .bin
Thanks,
Garcy
Reply 45 of 71, by garcy
ok cheers m8 ill try it and tell you if it works.
Reply 46 of 71, by b1_returns
help !! i get a error saying "mw2.exe -fatal #4d: SYSERR_CANTFINDVXRDRIVE : Unable to find video driver file." Plz help sorry for bringin up old topic !! 🙁
Reply 47 of 71, by Boreal Fadd
If anybody reads this thread still, thanks very much. I followed the instructions and have been really psyched with Mechwarrior 2, the reunion tour. It even plays well in 1024x768 although I haven't put the game through it's paces yet. Thanks to all who contributed.
Cheers
"It cannot be inherited and if you want it you must obtain it by great labour." T.S. Eliot
Reply 48 of 71, by darkgamorck
I can't believe this thread is still being read after all this time. Glad I could be of assistance though. Oh and by the way, DOSBox still rocks!
Reply 49 of 71, by ryt
U can look for mech warrior in wiki, u ll find some program theat it enables it to run in 2000 and in xp, but for mercenaries u still need dos or dosbox
Reply 50 of 71, by kontza
Nice one. Too bad that my Thinkpad X60s dies on DosBox+MW2 Mercs (I know this thread is specifically about MW2, not Mercs). Well, actually it's the display driver that dies, and with that whole of XP.
As I'm a SW tweaker by heart, I started examining the game with OllyDbg. After those examining sessions, I wrote few DLLs, and now I'm able to play MW2 Mercs v1.1 D3D on XP as a native app. I suspect that this solution should work with all games of the MW2-series.
Köntzä
Reply 51 of 71, by eobet
Version 0.70 makes this game even run fast in 640x480 (using dos32a). Amazing!
Reply 52 of 71, by The_Crank
I'm still having problems with the CD myself and the crank didn't work. So I'm back to the cd issue and i have my virtual cd mounted using daemon tools, and so i want to try to use the image mount program within dosbox, but i can't figure out how to use it and try it, any helo?
Reply 53 of 71, by MiniMax
Rank Moderator
Moderator
What kind of image do you have? How did you create it?
_________________
Reply 54 of 71, by leileilol
it'll work as long as it isn't virtually mounted, or if it's an ISO (but then you won't get the cool cd tracks)
long live PCem
Reply 55 of 71, by The_Crank
The Image is a .bin I created with power ISO
Reply 56 of 71, by The_Crank
so would it possibly work if I used the actual CD, and I'm using the latest DOSBox .72
Reply 57 of 71, by Qbix
Rank DOSBox Author
DOSBox Author
no. only the bin/cue support supports the cdrom detection they use
Water flows down the stream
Reply 58 of 71, by The_Crank
ok then, so since i do have the .bin image to I have to mount it within dosbox or should using daemon tools be ok?
Reply 59 of 71, by wd
Rank DOSBox Author
DOSBox Author
imgmount of dosbox
