Installed a Noctua NF-R8 1200rpm fan in the PSU. This one's almost inaudible but seems to push a reasonable amount of air.
Also fit the Gotek and managed to get it hooked up using the original floppy cable & 3.5 drive. The Tandy has 5V on pins 3,5,9 & 11 and 12V on 29,31 & 33, so it's necessary to cut those when connecting a non-Tandy drive otherwise you'll get a short circuit 😵
The Gotek seems to be working fine, I was able to boot from it and play Prince of Persia. My disk image selector doesn't work though so some debugging needed there.
Also fixed the power switch on my Tandy TTL monitor so we're getting towards a complete system. The keyboard should be over the Atlantic about now. Next steps will be to get the XT-IDE and DOM working.
