Reply 40 of 45, by ChrisR3tro
A thing that Wikipedia points out about the range of different Sound Canvases is that there are differences in sample rate. Most seem to have 32000 hz with some rare exceptions like the SCC-1. What do you guys think of that? Is there any truth to it?
I'm also considering to buy an SC-88 VL if I get a good deal somewhere.
for more Retro-related tidbits follow me on X under @ChrisR3tro.
Reply 41 of 45, by Bevil
yawetaG, thanks for you insight into this. I had no idea they actually did a re-compression of the original samples for the newer devices . That would further explain why the Microsoft licensed samples sound so low quality.
Reply 42 of 45, by yawetaG
Locutus wrote on 2020-04-26, 08:38:
It's quite possible, as Roland did the same thing with their other PCM synthesizers (JV/JD/XV/Fantom etc.).
Bevil wrote on 2020-04-26, 08:58:
If you look at certain ads, they allude to this. For example, many advertisements by Yamaha from the 1990s and early 2000s mention fairly large ROM sizes of 16, 24, etc. MB. These are not the actual ROM sizes you can find in the synths, which are in the single digit MB, but refer back to the uncompressed samples.
Reply 43 of 45, by andies66
Hi,
Good afternoon, I have a Roland Sound Canvas VA and I want to create a system exclusive for master volume using on Reaper. I read the midi implementation manual and input the system exclusive for master volume. But nothing is change and I'm not really sure if I do it correctly. This is the system that I input. F0 7F 7F 04 01 00 64 7F. 64 is the hex value for 100 in dec. Pls advice.
Thank you in advance
Andrew
Reply 44 of 45, by Falcosoft
andies66 wrote on 2024-07-03, 22:32:
Hi, Good afternoon, I have a Roland Sound Canvas VA and I want to create a system exclusive for master volume using on Rea […]
Hi,
Andrew
The right form is: F0 7F 7F 04 01 00 64 F7 . That is the closing byte is F7, not 7F.
Otherwise:
100% -> F0 7F 7F 04 01 7F 7F F7
50% -> F0 7F 7F 04 01 7F 3F F7
0% -> F0 7F 7F 04 01 00 00 F7
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 45 of 45, by andies66
Thank you so much for your help. Its ok now.
