Reply 40 of 55, by PARKE
Interesting aspect is that the boards seem to be 'mirrored'. Assuming that the rest of the design is similar we should be able to compare notes. The motherboard is a HP Red-Truck PCB rev 0A - Intel 915GV Express chipset.
My setup here runs on a 3.2 Ghz cpu with 2GB RAM.
64.7 KiB
[edit] Oh, forgot, and on XP Pro SP2
Reply 41 of 55, by murrayman
Yep, same chipset, though mine is a 3.0Ghz P4 with 1GB RAM. There was a third stick of 256mb that appeared to be original to the computer, as it was branded HP, but I took that out in order to have two evenly-matched 512mb. It's been forever since I messed with / looked up anything to do with hyper-threading, but IIRC, it requires matching spec RAM in even-number pairs?
Also, just for kicks and giggles since the ethernet works, I tried YouTube and found it perfectly capable of playing 720p videos. One of my old Toshiba laptops from '06 with a Celeron and 2GB RAM can barely do 144p. 😜
P3B-F 1.04, PIII 1k, 512MB PC133, GF DDR 32MB + DM3DII 12MB SLI, SB0100
P3B-F 1.03, PIII 700, 384MB PC100, V5 AGP, SB0160
CP 5170, PII 350, 256MB PC100, Rage LT 2MB, ESS 1869
PB M S610, PMMX 233, 128MB EDO66, DM3D 4MB, Aztech
Reply 42 of 55, by PARKE
No, I think you can put the 256Mb stick in an empty slot and it will work - but I doubt that you will notice any difference. And when the 256MB stick is of a slower Mhz rating than the other two the system will run via that slower rating.
More giggles here then, this HP is more or less my daily internet machine 😀
Reply 43 of 55, by Asaki
If it will let you enable the HTML5 player, you should be able to get even better performance.
https://www.youtube.com/html5
This laptop really struggles with video. I would assume it's because I have almost no video memory, but I could be wrong.
Reply 44 of 55, by shamino
The Prescott core is good for that, although many people don't like them for other reasons. It's better for video than the Northwood.
Reply 45 of 55, by cskamacska
murrayman wrote:
Looks like this system has a PCIe x1 slot after all.
Oh good news because that makes life a lot more simple. See the best PCI video card of the XP era for your system is..
a PCI-Express x1 video card. 😎
Zotac GeForce® GT 710 1GB PCIE x 1 - ZT-71304-20L
It is widely available everywhere for around 40 dollars(even here in Muzulmania almost all shops have it), and while still not an up to date gaming card it will fare MUCH better then anything you could get for a classic PCI slot. The card should have a 3.0 PCI-E connector, so in a more modern motherboard it could be even less limited. Has a Kepler 3D core, with 8 ROP 16 TMU 192 shader config, with a VP5 PureVideo decoder(same as GT520/610).
the loyal slave learns to love the lash
Reply 46 of 55, by uzurpator
Just about any PCIE card can be modified to fit into 1x slot. Either by opening the slot ( which might not be the doable here ) or by hacking off some of the edge connector of the card. Some DIY tutorials how to do it are on the net.
Theoretically, it should be possible to hack off Titan V to work on 1x, so for XP system it boils down to support for XP of a given GPU.
Die ewigkeit ist hier und jetzt.
Reply 47 of 55, by murrayman
Now that I know this system has a PCIe 1x slot, things have changed of course, but I may still play around with a standard PCI slot card just for fun. That's up for debate now since stats and benchmarks already exist for such cards out there, and thus I may go for the GT710 as recommended by cskamacska (especially since it comes with a low-profile bracket). But at the very least, this thread has served as an excellent discussion on and collection of links about XP-era / XP-compatible graphics cards. I'll report back again once I make a final decision, and exercise the Intel chip to see how buggy it is with gaming!
Reply 48 of 55, by Standard Def Steve
Just make sure you get a card with 128-bit memory. A PCI Radeon 9250 with 128-bit VRAM runs circles around an AGP FX5200 with 64-bit VRAM.
PCI Radeon 9250 128-bit:
285.49 KiB
AGP 8x FX5200 64-bit:
398.95 KiB
Reply 49 of 55, by PARKE
Looking at the photo of the SFF interior earlier in the thread it seems that there is limited space for a videocard on the PCIe slot because of the position of the cpu cooling system ?
Reply 50 of 55, by murrayman
PARKE wrote:
Looking at the photo of the SFF interior earier in the thread it seems that there is limited space for a videocard on the PCIe slot because of the position of the cpu cooling system ?
That's a mighty good point. I'll check dimensions of any card I may plan to place in there, both in relation to the CPU cooler and, if I go with PCI, with that one mobo connector.
Reply 51 of 55, by PARKE
That Gt 710 is just 16 cm long, see:
https://www.ebay.com/itm/1GB-HP-Compaq-dc5100 … d-/172242873741
But uhh.... for that kind of money you can get entire P4 systems that run circles around our 'poor office HP's 😉
Reply 52 of 55, by murrayman
WOW. That is nuts! Nah, I think I'd just go for this one. I mean, it's a whole centimeter shorter from the dimensions listed.
At least, I would... if it wasn't a 64-bit setup. 😅
Reply 53 of 55, by cskamacska
From the picture provided it looks like the chipset cooler wont be a problem since its cut down in 1 slot width, and the CPU cooler is far away enough from the end of the ZT-71304-20L. It may actually be beneficial that it faces the cooler, since heat spreader is so minimal(its a 20W card) it can help with sucking the hot air off of it.. right onto the processor. 😁
The biggest challenge might be the 3 capacitors near the opening of the slot, those may prevent the DVI connector to slide in its place, and maybe the toroid choke further down.
A Zotac GT 710 is 146.05mm long. Both cards are the same, but the 100 dollar version has scrubbed Zotac logo, so the poor victims think they are provided a custom solution and not just any old off the shelf video card.
Well you could always get a 128 bit Radeon 9200 card.. 🤣
But all the GT 430/520/610/710 and HD2400 Pro/3450/4350/5450/7350 PCI/PCI-E x1 cards are 64 bit so its not like we can choose like in the good ol days. 😀
Reply 55 of 55, by cskamacska
Well if anyone was wondering the GT710 version is markedly smaller than the GT730. GT730 front side cooling fins phisically block a second card from fitting on the left(so its a 2 slot cooling solution), and the ones pouring over the card on the right make the sound card behind a tight fit. GT710 on the other hand has a miniscule heatsink, feels like it came from 18 years ago. I could fit it right behind a GTX1060 without a problem, and still have room for ventillation. The whole card feels much more compact than the GT730 even though they both have the same PCB size.
Tldr; if size is a concern forget the GT730, the heatsink makes it as large as a compact version of the GTX1060/1070.
The 710 on the other hand is really tiny, and can fit in almost anywhere. Obviously it wont be as fast as its a cut down version of the GT730, but the video decoder part VP5 is the same.
