Reply 40 of 48, by jaffa225man
Marco wrote on 2026-11-08, 20:19:
Ha ha thank you - nearly 1 year. better late then never.
Thank you very much for the whole music recording. It was very enlightning to me to hear that new device in real GM usage.
Regards
You're very welcome! Good, I'm glad you like it, and yeah sorry about the year wait.
Strictly-speaking it's not really in GM1 mode once qmidiroute modifies it for my INTEGRA-7 remapping. GM1 resets are changed to GM2 resets. I needed changes like this more for GS synths to work with program forward (switching programs to set variations). If a GM reset is seen by GS synths, they can't be told to use variations, so I change them to GS resets. The SuperNATURAL sounds on the INTEGRA-7 don't need a GM2 reset to access them, but just in case this made more sense to me since it's a more capable standard. Anyway it works, although the sounds I've selected with qmidiroute to "Program Forward" are mostly SuperNATURAL here, with the obvious sound-effects still using its hidden Roland GS mode that Alistair discovered. 😀
In fact, in only that hidden GS mode, the INTEGRA-7 just sounds like a sound canvas to me. The HQ GM2 selectable sound banks don't seem that different either, but I'm assuming they use higher-quality bigger samples (I have used them here when I haven't found a SuperNATURAL or GS equivalent).
Reply 41 of 48, by Spikey
Cool that you did this! I might suggest that some of the program forwards could be changed, for example the guitars are muted instead of electric, and the Saw Wave doesn't seem to have enough attack (sounds like a square/saw combo), etc.
Also, reverb should probably be increased on the Integra, as it has a bug that keeps it too low. I recommend changing all reverb controllers to 127, but I forget what the optimal reverb type is now.
Reply 42 of 48, by Spikey
I did some comparison recordings of the Integra and SC-55mkII, I seem to remember the Integra sounds like the SC-55 emulation mode on the later SC's. Inaccurate, but close.
Reply 43 of 48, by Lord Myn
I'm using an MB MUSIC PRO.DX midi module: https://mbmusic-pro.de/en/sound-modules-for-p … b-music/#pro-dx, which is a Dream SAM5000 based GM module (GS compatible Reverb/Chorus and 3 Insert FX buses). It's sometimes surprisingly realistic sounding in DOS Games, but little bit unbalanced. My other choice is my old Audigy RX and the GeneralUser GS 2.0 soundfont with appropriate GS Reverb/Chorus compatible EAX settings.
Reply 44 of 48, by Spikey
Thanks for sharing that one Lord, hadn't heard of it! It indeed sounds great! As you say, not sure how it would work for actual DOS gaming, similar to Jaffa's Integra remapped example above which is literally hit or miss. But for composing or remixing I think it would be very useful!
Downsides are 32-note polyphony even on the Pro.Max version (EDIT: it's actually 256 on all models, some reviews or links say the wrong spec!), and the very very high price (one could buy a Roland XV-5080 or Fantom XR for the same money, for example!). Still, I'm glad it exists! Reminds me of a modern Ketron product, except Ketron has become so specialised to be completely unaffordable for anyone who isn't retired or wealthy.
A good MIDI page examples (70's/80s music, not games):
https://www.youtube.com/watch?v=wqHPJmtJG1U
That sax 😳
Reply 45 of 48, by Lord Myn
Spikey wrote on 2026-11-17, 07:34:
Thanks for sharing that one Lord, hadn't heard of it! It indeed sounds great! As you say, not sure how it would work for actual […]
That sax 😳
Yeah, I primarily use it for composing and remixing music. It has indeed 256-note polyphony and 32 (2x16) MIDI channels (the Pro.MAX has the same DSP and synth, only the physical layout is different). I had Ketron modules too (SD1000 and EVS) both had even better quality instruments than MBM modules, but the DSP control was far inferior.
Reply 46 of 48, by jaffa225man
Spikey wrote on 2026-11-16, 02:38:
Okay, I've got the all channels' reverb sends set to 127 when it encounters a SysEx reset of GS/XG/GM1/GM2, and any specific reverb send CC# 91 being rewritten in the range from 0-127 as 40-127. I chose to use 40 as a base since it's set to 40 on GS resets and you're saying it's too low by default.
Which E.Guitar do you think sounds muted enough (and is, preferably an SN-A choice)? I'm thinking I can change PC#29 to it, since GM says it should be a muted electric guitar.
The unusual Saw Wave you probably hear is the HQ GM2 Doctor Solo, which I miss hearing on the INTEGRA-7, otherwise. I wouldn't mind changing PC#82 from it if you think it can be applied somewhere else reasonably.
Anyway, thanks for the tips, and I won't mind getting you a recording with your suggested modifications!
Reply 47 of 48, by Spikey
Would you be able to rerecord with the new reverb setting first, if it's not too much trouble? Then I'll give the whole thing a listen. 😀
Reply 48 of 48, by jaffa225man
Spikey wrote on 2026-11-20, 05:37:
Sure, I'm recording it, but just to warn you this soundtrack sets reverb sends (cc#91) on each used channel (2-10) to 90, so it's using the multiplier rule 0-127 -> 40-127 (90/127*(127-40)+40) so it becomes 101 for each. As such, it's more subtle an increase than maximizing it at 127 would be.
Also to anyone else trying this right now, there's a bug in my qmidiroute patched version where these individual controller changes aren't being recognized as the "matched" messages they actually are, so the original reverb send message is output directly after the rewritten message is. That negates it obviously, but since I have the original unpatched qmidiroute also which doesn't have the bug, I'm chaining them for now to setup that simple rule.
Anyway, here's the recording: https://drive.google.com/file/d/1ktWZnIlVu7iM … iew?usp=sharing
