EIZO MD-B12 TIGA TMS34010
Reply 40 of 49, by Anderson77
Hi. Possibly, need to unite floppy and the disk drive and modern computer on same place. Where and how would be easiest to upload? Does it need to be image or just files?
Reply 41 of 49, by Predator99
You should be able to attach a ZIP/RAR archive directly here with your post? Just the files would be perfect - thank you!
Reply 42 of 49, by Grzyb
eisapc wrote on 2019-02-11, 15:06:
software for the following owned TIGA boards is availiable
ELSA Gemini
I'm looking for software for that card...
As of yet, I've found "ELSA XHR (DOS/W3.1)" stuff on Vogonsdrivers.
Is there anything else available?
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 43 of 49, by Predator99
gfernval wrote on 2020-11-04, 10:09:
Hello: […]
Hello:
for eisapc user:
Could you post the MIRO Tiger drivers? I haven´t found anywhere.
thanks
I am also an owner of a Miro Tiger now. Somebody got the drivers in the mean time? I am not able to find them anywhere...
The attachment IMG_2501.JPG is no longer available
The attachment IMG_2502.JPG is no longer available
Reply 44 of 49, by Grzyb
Predator99 wrote on 2024-10-18, 19:33:
Here you are...
Reply 45 of 49, by Predator99
Grzyb wrote on 2024-10-18, 21:10:
Here you are...
Wow..that was fast!
Thank you very much! 😀
I will test it in the next days and report. Thanks again.
Reply 46 of 49, by Grzyb
Predator99 wrote on 2024-10-19, 07:36:
Wow..that was fast!
BTW, see also the manual...
Reply 47 of 49, by Predator99
All working...thanks again! 😀
The attachment 20241019_120510.jpg is no longer available
The attachment 20241019_120452.jpg is no longer available
The attachment 20241019_120445.jpg is no longer available
The attachment 20241019_120027.jpg is no longer available
The attachment 20241019_120210.jpg is no longer available
Reply 48 of 49, by Grzyb
No 16-bpp modes?
Or they are listed on another screen?
Reply 49 of 49, by Predator99
At least in DOS, no. But resolution up to 2048x2048!
Maybe there are other options in Windows, but I dont have a insrtall currently.
The attachment 20241019_193435 (1).jpg is no longer available
