Reply 40 of 62, by Synaps3
OK, it doesn't work (the FX5500 PCI). Philscomputerlab has it working on the same board. Maybe it's because he is using REV 5 and I'm using 4.1
The problem is only with OpenGL. It works with DirectX all the way up to 9.0. The desktop goes all the way up to 1920x1200 at 32-bit color and seems accelerated.
Whenever I launch an OpenGL program, I get the message "The exception privileged instruction...."
I have tried a few versions of the ALi and ULi AGP driver and also tried installing the PCI PCI bridge driver (which is the correct one for PCI card I think).
It's pretty ridiculous how many drivers I have tried:
45.23 - installed, but didn't support the card (it supports only FX5200 and FX5600)
52.16 - same
53.04 - same
56.64 - works on desktop and DirectX, NOT OpenGL
56.72 - works on desktop and DirectX, NOT OpenGL
61.77 - don't remember, but doesn't work
81.94 - only works in desktop, no DirectX or OpenGL
93.71 - only works in desktop, no DirectX or OpenGL
I'm getting very tired of this board. Maybe I should just sell it and do another PIII build. Maybe PII would have better support.
I'm pretty surprised that it's not working with this card. Is there something else I should try to get OpenGL to work?
Systems:
BOARD | RAM | CPU | GPU
ASUS CUV4X-D | 2GB | 2 x PIII Tualatin ~1.5 GHz | Radeon HD 4650
DELL DIMENSION XPS 466V | 64MB | AMD 5x86 133MHz | Number Nine Ticket to Ride
Sergey Kiselev's Micro8088 10MHz | 640KB | Trident VGA
