Reply 40 of 42, by PC@LIVE
- Oldbie
I saw today that you are looking for a manual for the Acorp 5VIA3P motherboard, I have a motherboard with a MII 333 (3.5X75), if I remember correctly I have a 128MB dimm, but if you are interested I can restart the PC and provide more info.
Unfortunately I don't have the paper manual for that card, but in the link there is the online equivalent (images), I don't know if it has already been inserted previously, I hope it will be useful, regarding the BIOS the latest version available is not correctly recognizes the fastest CPUs, both MII 300 and 333 are recognized as 6X86MX 266, a mod would be needed, unfortunately I'm not able to do it, and I don't know if anyone wants to modify the BIOS, for those who would like a BIOS that correctly recognizes the installed CPUs, unfortunately in that motherboard there is no possibility to select lower voltages for the VCore, but by finding a way to lower the VCore you could also install a K6-2 400 (or more) , selecting 2X that the CXT remaps to 6X, then if 400MHz is not enough you could select 75MHz FSB, thus reaching 450MHz, 500MHz with 83MHz FSB is also possible, but I'm pretty sure the PCI will go beyond 41MHz, and here they could there be problems with the hard drives.
AMD 286-16 287-10 4MB
AMD 386SX-33 4MB
AMD 386DX-40 Intel 387 8MB
Cyrix 486DLC-40 IIT387-40 8MB
486DX2-66 +many others
P60 48MB
iDX4-100 32MB
AMD 5X86-133 16MB VLB CL5429 2MB
AMD K62+ 550 SOYO 5EMA+ +many others
AST Pentium Pro 200 MHz L2 256KB
