is this pc good?
Reply 40 of 59, by H3nrik V!
Yeah, waste of silicon might be a bad way of putting it. It was more a thought of not expecting the same boost from a Core2 or Pentium D in Win98 as you would've had over a P4 in an SMP capable os
Reply 41 of 59, by Shagittarius
C2D blows away a P4 in performance on Win98 even though it's only utilizing a single core. Core improvements grant a huge benefit over the P4.
Reply 42 of 59, by cyclone3d
Shagittarius wrote on 2020-10-05, 16:17:
Yes, yes it does. P4 was an absolute turd IPC-wise.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 43 of 59, by Jorpho
cyclone3d wrote on 2020-10-05, 06:56:
A Geforce PCX 5750 would be good (PCI-E Geforce FX 5700)
Or you could always go with an ATI X800 series.
Technically, you could go up to a Geforce 7900GTX or the Quadro equivalent
Do PCI-e cards work in Win9x, then?
Reply 45 of 59, by Oetker
I would definitely recommend a WinXP PC for 2003 games. However I remember playing Morrowind on my P3 666 with 384 MB ram and at first a Kyro 2 and later a geforce 3 for pretty water and it ran well enough for me. Curious what I'd think about the performance now.
Reply 46 of 59, by matthi321
would an IBM ThinkPad T40 or t41 with a ATI Mobility Radeon 7500 be better than the pentium4 mx 440 pc?
Reply 47 of 59, by DosFreak
Shit ATI drivers, mobile graphics chip. Likely worse but unknown what your definition of "better" is. It might work for your purposes.
/EDIT Use it and you'll see. Alot of us lived through those times. ATI was pretty rough back then. There is a reason Nvidia was on top and still is.
Make your games work offline
Reply 48 of 59, by matthi321
in what way are they shit?
Reply 49 of 59, by cyclone3d
The ATI drivers were pretty bad back then. Might not be as much of an issue now that we have easier access to all the driver versions.
Then again, nVidia drivers were not all that great either... and then nVidia also released drivers to cheat on benchmarks as well.
Remember back in the day where you would want specific driver versions for specific games?
YMF7x4 Guide
Reply 50 of 59, by matthi321
well i just bougth a t41 with dockingstation, i hope i wont get to many troubles with drives. thanks for all the help guys
Reply 51 of 59, by ODwilly
matthi321 wrote on 2020-10-06, 20:25:
The Mobility 7500 will be much slower than a Geforce 4 mx 440 I believe. That said I had a Compaq laptop with that Mobility 7500 w/64mb of dedicated VRAM and a 1.8ghz 533fsb Northwood core P4 and it ran Quake 3 @ 1024x768 at around 80-140fps with max details, which I thought was pretty dang good. Used Riva Tuner to OC the crap out of it to get the 140fps.
Reply 52 of 59, by chinny22
Yeh we played Quake 3 and UT on our laptops after work back in 2002-2005, which had a P3 and ATI Mobility.
It´s a laptop first and foremost keep that in mind with your expectations but it will run games of the era, maybe just not at full detail.
Good thing with the docking station is you can attach it to your existing keyboard, screen, etc then easily put it away when not using it, unlike a full on PC
Reply 53 of 59, by matthi321
i just found my brothers old pc will i be able to install 98 se on this and are their drivers for all the hardware?
acer aspire t135A- sb7z
mobo: k8vm800mae
cpu:amd sempron 3000+
gpu:radeon 9200 se
2gb ram
160gb hdd
Reply 54 of 59, by chinny22
matthi321 wrote on 2020-10-14, 10:15:
Looks good
I'm assuming the MAE is the OEM variant of the K8VM800M of which drivers are here
https://www.gigabyte.com/Motherboard/GA-K8VM8 … pport-dl-driver
Radeon 9200 se
https://www.philscomputerlab.com/ati-9x-driver-archive.html
Should be enough to get you started! 😀
Reply 55 of 59, by matthi321
ok its good their are drivers for it 😀 but isnt 160gb and 2gb of ram to much for windows 98 se for it to work?
Reply 56 of 59, by chinny22
160GB is fine, although I'd create smaller partitions. On all my builds I give Win98 a 4GB partition, a nice large partition for games and another "recovery" partition with windows cab files, drivers, etc
2GB is definitely not needed and will probably even cause problems, but you can either reduce the ram (best option) or patch/tweaks exist to force windows to work with high amounts of ram
Reply 57 of 59, by matthi321
ok are their tutorials for creationg smaller partions and patch the ram? will their be problem with games if i patch the ram?
i tried to use the 512 ram stick from the dell pc but it would not fit on the mobo. how can i tell if i buy some ram online if it will fit on the mobo?
Reply 58 of 59, by chinny22
Fdisk
https://youtu.be/satl8PNW_DI
However you'll want to use a WinME bootdisk as it's version of fdisk supports larger drives
https://www.bootdisk.com/bootdisk.htm
Once you create the partitions reboot using your Win98 disk/CD and carry on as normal
Ram
Easiest way is probably the RLoew patch. It has instructions in the zip but no youtube video I'm afraid
His family kindly made this freeware when the creator passed away, so its obviously no longer supported
https://archive.org/details/PATCHMEM
The good thing is 2GB should still install Windows without crashing IFAIK it just struggles to address it all.
Some games may have issues, you can "eat up " ram with a ramdisk which is what I do but worry about that after you have the system up and running 😀
That motherboard takes DDR400 PC3200 RAM. It doesn't have dual channel or anything like that so no need to install in pairs.
Reply 59 of 59, by matthi321
ok this seem a bit complicated for me but i will give it a try.thanks for your help 😀
