Ultimate Dual Pentium II@333mhz
Reply 40 of 72, by Intel486dx33
Oerg866 wrote on 2021-09-02, 11:33:
This is not an AGP card :p
Oh yeah, Hey I can use this card in my Win95 build then.
Reply 41 of 72, by Stiletto
Merged four threads belonging to Intel486dx33 that were all related.
do the Fandango!" - Queen
Stiletto
Reply 42 of 72, by Errius
OT. I have a R440LX which has a 24-pin power connector which is the same physically as a modern ATX connector, but which is wired differently. Presumably anyone who plugged a modern PSU into it would blow up the board or the PSU or both. Intel why yuo do this????
"This all reminds me when i took the windows vista sticker thingy off my old laptop, and on my washing machine as a joke. A few days later said washing machine stopped working. I still think this cannot be a coincidence."
Reply 43 of 72, by Intel486dx33
Errius wrote on 2021-09-02, 22:32:
Yes, as some as I get this NOS PSU I will check the wiring and make sure all the voltages are correct.
The motherboard has a detailed manual with all the connector wire voltages listed.
Reply 44 of 72, by Intel486dx33
Okay, I put in the NEW PSU and its booting now. It boots into bios on its own.
But the PS/2 keyboard does not work.
I tried both PS/2 ports.
I get a “keyboard error” on boot up.
I think it was error code 0211
The manual reads you can use either port.
https://www.elhvb.com/mobokive/archive/intel/ … LX_68271701.pdf
Any ideas on how I can get the motherboard to work ?
Reply 45 of 72, by PC Hoarder Patrol
Well at least the new psu has it booting (of sorts)
What happens if you now set jumper J7E1 to pins 2-3 (forces the system into configuration mode) - does the keyboard work now?
Jumper J7E1 - download/file.php?id=118245&mode=view
Reply 46 of 72, by Caluser2000
Stiletto wrote on 2021-09-02, 21:51:
Thank you so kindly...😉
Reply 47 of 72, by Caluser2000
Intel486dx33 wrote on 2021-09-03, 20:21:
Okay, I put in the NEW PSU and its booting now. It boots into bios on its own. But the PS/2 keyboard does not work. I tried both […]
Give a small live linux a shot booting from optical drive or usb port.. It give more info why things aren't. My even pick up a usb keyboard.
Looks like needs the bios configured.
Reply 48 of 72, by Intel486dx33
PC Hoarder Patrol wrote on 2021-09-03, 21:03:
Yeah, setting that jumper has it booting into bios. But the keyboard is not working.
If I put the jump back to 1-2 the computer boot a black screen with error some kind of error.
Any other way to reset the bios to default settings ?
Reply 49 of 72, by Intel486dx33
Caluser2000 wrote on 2021-09-03, 21:35:
Any ideas on how I can get the motherboard t work ?
It won’t boot from any device.
Reply 50 of 72, by Intel486dx33
Something else I noticed is its booting with CPU speed of 133mhz when the CPU is a 266mhz ?
Let me try another CPU.
Reply 51 of 72, by the3dfxdude
Intel486dx33 wrote on 2021-09-03, 21:37:
Do you have a floppy drive? The earlier screen shot I'm not sure you hooked one up. I don't remember at what point BIOSes became compatible enough to use CD and USB. Right around that time I always carried a floppy for starting an OS install. In fact a few days ago, I installed Win2000 on a dual P2, and I needed the floppies because the CD did not boot on it. Circa ~1997 board I think. But the BIOS has date codes from '99. I think I had updated the BIOS back in the day.
Bah, and when I pulled out one old my Win2000 boot floppies, one of them did not work... oh memories. At least it was a quick fix.
And one more thing, most Linux OS boxed from the store from back then would give you a setup floppy too... just a hint, this was still frequently needed.
Edit: But yeah, if you try to boot modern Linux OS from a live CD/USB, you may need a boot floppy.
Reply 52 of 72, by Caluser2000
Lots of questions. Do you have a suitable ide hdd attached? I don't see any errors for one. Invalid drive type, non operating system etc.......
Reply 53 of 72, by PC Hoarder Patrol
Did you try a USB keyboard ?
Reply 54 of 72, by Intel486dx33
I tried other single CPU’s of different speeds but the bios still sees them as 133mhz ?
Dual CPU’s appear to be working but at 133mhz too.
The keyboard does not appear to be working at all.
The keylock and num lock dont work either.
USB keyboard does not work either.
Was there ever such a thing as a Pentium II @ 133mhz ?
Reply 55 of 72, by PC Hoarder Patrol
Because the system is unconfigured, it's defaulting any installed processor to the lowest possible setting ie 2 x 66MHz
Reply 56 of 72, by Horun
Intel486dx33 wrote on 2021-09-03, 22:10:
Do all the keyboard LED's flash shortly after powering on ? If not maybe they are not getting the +5v. Even when KB controllers fail the AT and PS2 KB will usually (but not always) flash all LEDS once if they are getting power.
Reply 57 of 72, by Intel486dx33
Horun wrote on 2021-09-03, 23:07:
The keyboard lights flash quickly then turn off. But the num lock and caps lock don’t work ?
Reply 58 of 72, by Caluser2000
How many ps/2 keyboards did you try?
