Reply 40 of 45, by Vovichx
Recently, I bought a Matrox G450 G45FMDVP32 PCI card on AliExpress. I tried using it with Windows 98 SE on a Lucky Star 5I-VX2B motherboard (Intel 430VX chipset) with a Socket 7 AMD 5k86 P90 90 MHz CPU.
At first, I had a problem with the drivers — for some reason, the Matrox driver installation 6.83 did not detect any devices, while Windows suggested installing the Standard VGA Driver. I manually selected the driver "Matrox Millennium G450 DualHead DVI PCI – English", and it installed correctly.
It works quite well so far. I’m using a DVI-to-HDMI cable to connect it to a modern Samsung LS27D600 monitor. This is the first video card that has successfully displayed the BIOS and DOS screens on this monitor.
One thing that’s a bit annoying: When switching to DOS mode from Windows, the image becomes unstable, and the monitor sometimes loses signal and turns off briefly before recovering. This doesn’t happen in pure DOS mode, so it’s likely related to how the Windows driver handles the video mode switch. I’d be happy if someone could advise me on how to fix or improve this behavior.
Reply 41 of 45, by b0by007
Vovichx wrote on 2025-10-28, 19:08:
This problem was discussed by Phil, from PhilsComputerLab: https://youtu.be/ft6eoyxT1ik?si=FODYLvz7afAYQGQS
HP Vectra D2753A 486/25N i486 SX 25mhz
UNISYS SG3500 AMD486 DX2 66mhz
OLIVETTI M4 i486 SX2 50mhz
IBM PC 330 6577-79T, Pentium 166mhz
IBM PC 300GL 6561-350, Pentium II MMX 266mhz
My retro youtube channel!
Reply 42 of 45, by B24Fox
I recently discovered a nifty little DOS TSR utility by TheGreatCodeholio, called "VGA240.EXE".
It is part of a larger pack of utilities called doslib.. But this basically makes DOS run in 640x480@60Hz instead of 720x400@70Hz.
I found it very useful at fixing some "ugly pixels" in 320x200 and 640x400 resolutions, and DOS screen tearing issues that I had on my LCD on the VGA port. Maybe it works on DVI too..
Here's the discussion about it: VGA Capture Thread
It's not perfect, as it messes up some games that have some of their timings tied to the refresh rate; and even may reduce performance if you're using a PS/2 mouse (no problem on serial).
But it is what it is, and it MASSIVELY reduced screen tearing in DOS games, and made the LCD sync up very nicely.
There are many versions of this utility in the GitHub archive, and I only tried the one from Sep 25-2019 in the folder named "hw/vga/dos86s" as it's said to have the smallest memory footprint.
I have no clue how the other variants behave.
<<The UNIFIED Passive-Adapters Thread for Mice, Keyboards, Joysticks & more>>
Reply 43 of 45, by Kahenraz
Does it support 640x480@70Hz? Would this fix the timing issues?
Reply 45 of 45, by Vovichx
Kahenraz wrote on 2025-10-29, 06:20:
I conducted a couple of tests on the Samsung LS27D600 monitor with a DVI-to-HDMI cable and the Fujitsu B19-7 monitor with DVI and VGA cables.
Samsung LS27D600
DVI-to-HDMI cable
Pure DOS: 642x480@60Hz - This is stable:
The attachment LS27D600-pure-dos.jpg is no longer available
DOS app under Windows 98: 1246x480@60Hz - This is unstable:
The attachment LS27D600-dos-under-win98.jpg is no longer available
Windows 98 desktop: Stable at any possible resolution.
Fujitsu B19-7
DVI cable
POST screen: 480p@60Hz - This is stable:
The attachment Fujitsu B19-7-DVI-POST.jpg is no longer available
DOS app under Windows 98: Out of range, no picture.
VGA cable
POST screen: 640x350@70Hz - This is stable:
The attachment Fujitsu B19-7-VGA-POST.jpg is no longer available
DOS app under Windows 98: 720x400@70Hz - This is stable:
The attachment Fujitsu B19-7-VGA-dos-under-win98.jpg is no longer available
Windows 98 desktop: Stable at any resolution. For the standard resolution of 1280x1024 on this monitor, I could enable a 75Hz refresh rate, which is cool.
I can conclude that the Fujitsu B19-7 with a VGA cable is the best choice in my case. All modes are stable.
