Reply 40 of 44, by Zeerex
This board already has USB (albeit 1.0). Have you tried it without the card?
Zeerex wrote on 2022-05-26, 01:56:This board already has USB (albeit 1.0). Have you tried it without the card?
100% this, if you already have onboard USB just freakin use it
hell with USB 2 cards they belong in the trash can
USB 2.0 cards are not that useful anyway. USB 1.0 is sufficient to transfer drivers while a network card is a better option than USB 2.0. I transfer files to my Windows 98 machine exclusively through NAS.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,16GB,GeForce GTX 980 Ti
I'm happy with the USB 2.0 card I have in my Amptron P4 system (Having USB 2.0 front ports is nice) with Windows 98, but that system is powerful enough so that it has a negligible performance penalty. OP could go either way, it just depends on his priorities.
I definitely draw the line on my Socket 7 systems; the onboard USB is more than good enough considering the performance loss of a USB 2.0 card.
A lot of times when you first start out on a project you think, This is never going to be finished. But then it is, and you think, Wow, it wasn't even worth it. - Jack Handey
i found out to the lower speeds i was getting happened when a usb flash drive was plugged into a port connected to the usb card but when the drive is unplugged then the speeds are in the 80s
