lutiana wrote on 2022-08-14, 20:29:So an update to this. I got the 700Mhz CPU and had nothing but issues getting it to work on this board, even got the Ebay seller […]
So an update to this. I got the 700Mhz CPU and had nothing but issues getting it to work on this board, even got the Ebay seller to send me another one (which never even posted). And while dealing with this I stumbled onto an ASUS K7V motherboard (the version without onboard audio) and 750Mhz Athlon and I bought and have switched out the Biostar board with this one and decided to keep the Voodoo3 for now.
Quake 2 runs buttery smooth on this setup, I don't have a frame counter, but @800x600 it looks like it's in the 60FPS ball park with no slow downs at all.
So my next question is for recommendation on what to run on this thing? What are some gems that I can run on this thing?
My next step is to find a decent case for this thing.
Well u got alot of advices, but one another can help too. If was me, id go with the ASUS board (yes i hate that brand), but it should be ALOT more stable and well build then the shitty BIOstar. I prefer GIGAbyte boards, but i dont own one of them in my Slot A collection.. For Audio u want for sure Aureal VorteX II card, for the A3D, it is insane everyone will tell u that much. But their price is usually high AF ofc, so if u cant find one for good price just get some compatible non OEM Creative Live 5.1 they work very nice for 98 games as well... For the GPU stick with the 3Dfx Voodoo III, as the card and brand is pure classic, while nVIDIa is not as interesting, no matter is similar in performance.
Another advice if, u are using some garbage chinese cheap power supply, replace that crap, with some brand like Seasonic, Delta, EnermaX whatever, otherwise it may blow up and kill most parts... For even more retro effect, you can find and use Quantum Fireball HDD, but they are load AF keep that in mind.. For case depends, what u are looking for, there are expensive Cooler Master aluminium cases, there is also the non named white chinese cases, or the OEM ones.. My advice here will be, find some cheap OEM case like Compaq or IBM one, and look ofc to be compatible, as they like to do crap stuff. And yes u can find such a case and use the PSU from it as well, they are usually very high quality... You better replace that x2 64mb, as it may cause problems, specially if all 3 sticks are different brands, and specially different chips on them... Better to find x2 128MB some quality OEM memory like Infineon, Micron, HyniX, Samsung...
Here some pictures, as u may not know what i mean.. These OEM cases are fine, only the compaq did have BS with the PSU mounting, but most of them are just fine... It is the best choice, since they are cheap, idiot proof, and they have also high quality PSUs, and also i like very much how they look both of them, so it is a win-win-win with OEM cases... They even have quality fans as well, that is a bonus too...
The attachment 20220519_164419.jpg is no longer available
The attachment 20220519_152725.jpg is no longer available
The attachment 20220519_135333.jpg is no longer available
The attachment 20220519_165147.jpg is no longer available
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
