The Force Engine (Dark Forces Port)
Reply 40 of 43, by gerwin
The Force Engine v1.09.500 with true color GPU rendering option is out, as already mentioned in the other topic.
So I decided to build a Win32 / XP binary of this version. And it all seems to work fine, eventually. It was just uploaded to my website.
Reply 41 of 43, by gerwin
gerwin wrote on 2023-09-24, 22:18:
Whilst working on this I spent some time to find a bug in the audio section, a memory read/write out of bounds, which causes an immediate crash under Win32, though the x64 version is seemingly more tolerant to this issue. LuciusDXL just fixed it up properly, and a bugfix release will probably follow soon. In a week or so I will update my Win32 build to the more proper fix as well.
https://github.com/luciusDXL/TheForceEngine/issues/329
https://github.com/luciusDXL/TheForceEngine/c … e183534371e1f31
Reply 42 of 43, by gerwin
gerwin wrote on 2023-09-25, 14:36:
I just build and uploaded a new executable with all the commits from today. That makes it "v1.09.500-4-g609ff030".
The sound handling is not just crash-fixed here, but properly fixed as it was intended. In addition this adjustment was made to the GPU shaders:
https://github.com/luciusDXL/TheForceEngine/issues/334
With that last change I can actually run all GPU accelerated modes at 1440x1080 at around 60FPS, on a Radeon HD7750 that is. Much better then before.
Reply 43 of 43, by gerwin
gerwin wrote on 2023-09-25, 22:57:
Seemingly the GCC compiler does not auto-initialize variables to zero like MSVC. Meaning the video recording was always on, causing lag.
https://github.com/luciusDXL/TheForceEngine/issues/363
This is fixed now in my WIN32 / Windows XP build v19-10-2023. Should run a lot smoother.
