Reply 40 of 3298, by BEEN_Nath_58
sharangad wrote on 2023-08-14, 10:16:
BEEN_Nath_58 wrote on 2023-08-14, 09:46:
About QUAKE 2 issue, the problem occurs always, regardless of settings.
Edit: If I start game without rendition and then launch RReady and put vid_ref v1k, it still gives the "couldn't create window" error.
Shims it is then.
Quake 2 is a well behaved game, it shouldn't be giving you grief.
It is a well behaved game. SW, OGL and 3Dfx MiniGL runs well. Redline doesn't do like that Anyways I would need the next instructions (till then I am trying to make Grand Prix Legends work, it crashes)...
Reply 41 of 3298, by BEEN_Nath_58
BEEN_Nath_58 wrote on 2023-08-14, 10:20:
Shims it is then.
Got Grand Prix Legends to work ON A BLACK MENU. It strangely needed the No Ghost shim on top of the DxWnd Handle Exceptions setting. The game would otherwise crash innocently.
Reply 42 of 3298, by sharangad
BEEN_Nath_58 wrote on 2023-08-14, 10:36:
Shims it is then.
GPL support is currently incomplete.
https://patreon.com/Rready
Reply 43 of 3298, by sharangad
Shims it is then.
No I mean it's well behaved with RReady. What's in the log file?
If you chuck those two files in the baseq2 folder does it run and the ref_v1k file in the root game folder AND keep the launcher running does it run?
Is there a shim to restrict resolutions to 1280x1024?
Reply 44 of 3298, by BEEN_Nath_58
sharangad wrote on 2023-08-14, 10:57:
Shims it is then.
Finally I got the problem. The fullscreen setting that I had to change was in config.cfg, not the one in RReady. And I had to set it to 0, instead of 1
Reply 45 of 3298, by sharangad
BEEN_Nath_58 wrote on 2023-08-14, 11:07:
Phew! That's a massive relief.
Reply 46 of 3298, by sharangad
A few games that still don't have an answer to the EmulateHeap bug is: Jane's Longbow 2 book reading screen, GTA Vice City Win98 […]
A few games that still don't have an answer to the EmulateHeap bug is: Jane's Longbow 2 book reading screen, GTA Vice City Win98 compat mode, Lords of the Realm...
Most of these games don't use RRedline at all. vHexenII was our subject. Although DxWnd attached magic to EmulateHeap somehow, without it the game would run 1/15 times.
My suggestion saying this was: consider setting shims individually over compatibility mode.
Also EmulateHeap isn't the only problem; there's problem with EmulateGetCommandLine because Windows no longer sets up DOS lengths paths anymore (by default)... but all of this is a topic for later.
You can disable Win98 compatibility for vHexen II from Rendition settings. In the lower section you can set it to current windows.
The list of shims I have is this:
https://learn.microsoft.com/en-us/windows/dep … d-windows-vista
It seems to be missing a whole lot.
Reply 47 of 3298, by BEEN_Nath_58
sharangad wrote on 2023-08-14, 11:15:
You can disable Win98 compatibility for vHexen II from Rendition settings. In the lower section you can set it to current window […]
You can download Microsoft ADK, and install Compatibility Toolkit from there. You should get most things there.
Reply 48 of 3298, by BEEN_Nath_58
I checked your MechWarrior 2 video. It is Mercenaries, andit gives the same problem. You missed a step I said.
First you'll need to run the game on Direct3D. Then exit the mission and then launch on RRedline. That's when you'll get the flickering issue (copyback=0)
Reply 49 of 3298, by sharangad
For "Die by the Sword" GOG version.
~ 16BITCOLOR EmulateGetCommandLine EmulateHeap
works really well. No more random crashes. Added to the launcher.
Reply 50 of 3298, by sharangad
BEEN_Nath_58 wrote on 2023-08-14, 11:34:
Yeah because the window is DirectDraw based. You can't force a DD window to be an opengl one or vv.
I'll check that out now.
Reply 51 of 3298, by BEEN_Nath_58
sharangad wrote on 2023-08-14, 11:45:
For "Die by the Sword" GOG version. ~ 16BITCOLOR EmulateGetCommandLine EmulateHeap […]
I don't recall the game needed EmulateGetCommandLine and EmulateHeap when I tested it 3years ago (where's the crash/problem that needed you to add this, more curiously why EmulateGetCommandLine). By the way, the other compatibility "modes" (such as color modes, run as admin, disable FSO) work as a protective layer that enables FaultTolerantHeap (introduced in Win7) that takes care of such EmulateHeap problems.
Reply 52 of 3298, by BEEN_Nath_58
BEEN_Nath_58 wrote on 2023-08-14, 11:50:
sharangad wrote on 2023-08-14, 11:46:
The problem appears only after the game has been run on a different API (I don't know why there shouldn't be a DD window earlier, but there should be one after you clearly exited a D3D session)
Reply 53 of 3298, by sharangad
Before the launcher set the string to "~ RUNASADMIN 16BITCOLOR WIN98"
This caused the app to randomly refuse to startup or produce slow mo menus. When it did start up it it took a long time to escape a black screen.
Not sure the commandline param's needed.
Trawled through the list and didn't really notice anything to restrict resolutions. for hexen 2. Will have another trawl now.
Reply 54 of 3298, by sharangad
BEEN_Nath_58 wrote on 2023-08-14, 11:51:
Restarting the game after toggling renderers (without copyback) should work, but you're right in that it's not ideal. The same problem would occur when switching from Rendition to Direct3D.
Reply 55 of 3298, by sharangad
sharangad wrote on 2023-08-14, 11:58:
This caused the app to randomly refuse to startup or produce slow mo menus. When it did start up it it took a long time to escape a black screen. Without it it wouldn't run at all on my system.
Reply 56 of 3298, by sharangad
Could you tell Gho that if an app complains about the the launcher not running, to restart the launcher and then run the app from DxWnd?
Connected drives/network shares/usb drives can sometimes affect licensing. it's not supposed to, but it does..
Reply 57 of 3298, by sharangad
Could the shim EmulateDirectDrawSync help? RReady renders from another thread. I'll mess around with the config tomorrow in Compatibility Administrator.
Reply 58 of 3298, by BEEN_Nath_58
I never had to use EmulateDirectDrawSync myself. There could be some apps that pre-applied it. That's all that probably needed it. DxWnd did half the work of the shims so maybe they were needed but I never saw.
EmulateGetCommandLine shim shouldn't generally be required. It was needed in Dungeon Keeper because that game's command line options have to be set with a DOS supported path format length.
About the black screen, I am aware of the rendering and synchronisation issue of the menu. I last tested it 3 years ago, I will check again tomorrow (we have Independence Day tomorrow so there's some free time). The two shims don't correspond to fixing the menu issue so it's interesting.
Btw how are you even setting the shims through RReady Launcher?
About the MechWarrior 2 situation, do you mean to say the problem occurs even when doing the same procedure from RRedline to Direct3D? Strange, that is not an issue for me. I only have an issue when I run Direct3D first and RRedline later.
Reply 59 of 3298, by sharangad
BEEN_Nath_58 wrote on 2023-08-14, 15:20:
I never had to use EmulateDirectDrawSync myself. There could be some apps that pre-applied it. That's all that probably needed i […]
Maybe I'm not setting the Shims. I just added the shim names to compatibility strings in the registry. "Die by the sword" has startup and menu issues with redline. Most probably the 'shims' I set weren't being set and the game was running without any settings.
MechWarrior 2 going from dx to redline shows problems. The other way has no issues. So it's most probably a directdraw surface issue with open gl. I did check buffer swaps.
The other thing is mw2 should be able use higher resolutions. I think DxWnd is blocking it. Redline allows the resolution to be changed and the mechanism rready uses to go higher than the target is generally solid.
Team apache is next on my list for now. I have tried pressing escape on the videos before and got a lockup.
I think in terms of compatibility the low hanging fruit had been plucked.
Gpl's exceptions are caused by my code. I had the menus with a black background working reliably at 640x480 without any compatibility settings. Upscaling needs fixes because the game expects mouse coordinates to be in 640x480 range. Some letters were missing from the menu items.
Thanks for all your help, and the Vogons community too. I would've hit a brick wall otherwise.
Happy independence day tomorrow!
