help slow boot
Reply 40 of 43, by weedeewee
scroeffie wrote on 2023-08-31, 21:08:
deturbo is turbo switch on ,i wil change all the jumpers for new once tomorrow ,friend of mine says he is 90% shure the cpu has […]
deturbo is turbo switch on ,i wil change all the jumpers for new once tomorrow ,friend of mine says he is 90% shure the cpu has some kind of damage and or slow external cache
i think the manual is lying and max cpu speed is 66mhz
the bios i did not change thats the original ami bios that came with the pc .i also tried sram modules just to be shure
i wil try the other ram slots ,i did remove the external chache but no change but wil test again tomorrow
is the one i have newer ? 40-0B03-428045-00101111-121593-OP802G-H < maybe one is for pci and one for vlb ?
i dont have a board to test this dx4 100mhz cpu just to be shure its not the cpu .friend says its the cpu .people on discord say its the motherboard
but the dx2 50mhz works perfect 0 problems with turbo on and off
wil keep you guys up to date
I already mentioned the FSB vs CPU frequency thing.
Can you upload the bios you have ?
You could try running the dx2-50 at 66, see if that works, just long enough to test the turbo/de-turbo.
edit: dx4 cpu fault feels likely to me at the moment.
Do not ask Why !
Reply 41 of 43, by scroeffie
iam giving up just doesnt work i think the manual is BS thanks for all the help
Reply 42 of 43, by scroeffie
i got the 100mhz working voltage jumper was wrong got confused ,thanks for helping
Reply 43 of 43, by rasz_pl
rofl 🤣 glad it worked in the end
of course I should have spotted that 🙁, I already posted about
> Comparing jumper tables it looks like Jumper 16 dual block is responsible for switching between 5 and 3.3V
and then you uploaded picture with those jumpers set to 5V. Luckily sounds like you didnt manage to fry the cpu
