Reply 400 of 894, by Peixoto
- Member
wrote:Hello there. Windows 10 Home 64, GeForce GTX-670, Ryzen 1700. Got a similar issue with Tomb 2 but slightly different, maybe it c […]
wrote:when I want to run any Tomb Raider I get Unable to find or load C/: Users/... /Peixoto/peixoto.dll-126
Got a similar issue with Tomb 2 but slightly different, maybe it can cast some more light on it.
First I get "Failed to load D3Dx9_43.dll, some features will not work, make sure DirectX is up to date"
then I get "Unable to find or load (here my folder path to peixoto)\peixoto.dll-126"
I downloaded the patch few times, installed vcredist 2008, both x86 and x64, pasted d3dx9_43.dll.
I see tomb2.exe window opens but it closes as soon as I dismiss those error messages.
I read in earlier posts directx files are now a part of windows sdk, should I do something with that?EDIT: OK I just noticed I got the link from this thread here, I thought it would be the latest one.
Now got one from tombraiderforums and it seems to work. However this happens instead.
https://youtu.be/fGT4s7CCOlg
Any link on the Tomb Raider foruns that doesn't link to this thread is not up to date.
Dependencies of the current version are are:
- vc redist 2010 (you probablly already have)
- vc redist 2015
- DirectX june 2010 or latter (That it not part of windows 10. Win 10 has some DirectX APIs, but not all of them)
Failure to load peixoto.dll is either becuse you are missing vc 2015 or your antivirus has quarentined it
If the problem in the video is the missing textures, thats because you are activating the texture search function: "i" or "u" by default (i don'r remember).
Change the key binds for the texture search function or in the game
