Reply 40040 of 53143, by BitWrangler
- l33t++
HanJammer wrote on 2021-08-06, 11:04:BitWrangler wrote on 2021-08-05, 21:29:Could find a motorola CPU in there. VME bus control system or something.
Yeah. It has 6809 in it with boards marked as 'EPSILON'. It also has stickers with a date the modules were tested (20.11.84 so few years before VME was standarized). Do you have any idea what it may be?
Don't really know anything else. For A 6809 system, suspects include SS-50 and STE bus, OS/9 operating system or a version of CP/M or SWTPC Flex. Also 8 bit motorola systems often used a motorola supplied BIOS type firmware called MICBUG which had basic monitor, debugger and bootstrap functions so if you find something like a serial port, you might be able to use whatever the standard procedure is to get into that.
