Reply 41460 of 57606, by Vynix
Nexxen wrote on 2021-12-14, 23:26:
xcomcmdr wrote on 2021-12-14, 22:01:
Just like the HP Omnibook XE3-GC I used to have (but the Omnibook's screen was shit).
I have 2 and the screens aren't that bad.
S3 + Polka audio! 😀
I've got one as well, with the XGA screen, unfortunately mine isn't in the best of condition and needs a new HDD connector (previous one crumbled in my hands grrrrr), but otherwise it's a pretty solid performing laptop
Reply 41461 of 57606, by TrashPanda
Been handed more old hardware today a couple of old Compaq servers, so now I have a boat load of PC133/PC100 ECC dimms about 6 256mb ones and 12 128mb ones, no idea if they will work in my 370 board that supports ECC dimms but only one way to find out.
Also have 5 70gb SCSI Ultrawide320 drives, 3 18gb SCSI Ultrawide3 drives and two 9GB Ultrawide3 drives, not sure if finding a SCSI Ultrawide PCI card and repurposing them in my Tualatin system would be worth it, not even sure if you can get a card that supports both at the same time. Guess its time to do a little research since throwing out 15k RPM drives would be such a waste, the servers dont work and trying to restore them would be impossible, they were raided systems and each is missing drives from the array. The servers are also missing PSUs and any of their management software, they do still have their SCSI raid cards in them but no way to reuse them in a PC.
Also have 4 700Mhz Pentium III slot based Xeons too, pretty sure they are useless without a server board for them, might crack them open clean them up and cast them into blocks of resin to use as drink coasters!
If anyone has pointers for SCSI drives and cards or links to good online resource that would help in trying to reuse the drives I would be grateful.
Edit - Is Ultra320 backward compatible as in itll work on earlier Ultrawide cards but at a slower speed ?
Reply 41462 of 57606, by cyclone3d
The scrap lot with the Compaq ESS wavetable board came in. Nothing else really to talk about but there were a few pieces that aren't going right back to scrap.
The ES689F / ES982 daughterboard:
The attachment Compaq_ES689F_ES982_front.jpg is no longer available
The attachment Compaq_ES689F_ES982_back.jpg is no longer available
Anybody have any idea what this is for?
The attachment Formats_Unlimited_v.2.1.jpg is no longer available
Also got a few things worth saving that aren't pictured:
K6-2 300
S370 PIII-933
Itanium 2 900Mhz - ton of bent pins
10/100PCI NIC
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 41463 of 57606, by TrashPanda
cyclone3d wrote on 2021-12-15, 02:05:
The scrap lot with the Compaq ESS wavetable board came in. Nothing else really to talk about but there were a few pieces that ar […]
K6-2 300
S370 PIII-933
10/100PCI NIC
The Itanium cleaned up and opened showing the core would make for a great wall piece, not really much else you could do with it.
Reply 41464 of 57606, by BitWrangler
The chip on the left is for remembering, the chip on the right is for logicing and the thin one is for resisting. As a whole.... I've got no clue.
edit: after a bit of pondering... you could plug a 26 Pin JVC hard drive into that header and see if it blows up, then at least that's one less of the stupid things 🤣
Reply 41466 of 57606, by appiah4
I bought a bunch of PCI-E cards.. A Radeon HD4870X2, a GTX480 and a GTX780. Untested, and belonged to seller's son, and were placed in a cupboard after upgrading. They are supposed to work. I paid only $35 for the lot, so even if only one of them work, I'll be good I guess..
Reply 41467 of 57606, by ODwilly
Might be picking up a beige Antec case, a Z68 gigabyte board, 16gb of ddr3, 600watt PCP&C psu, 128gb ssd, 500gb HDD and a Xeon e3-1270 tomorrow.
$45 and I was after the case. But along with the R9 Fury I loaned out to a buddy last year I guess iv got a full "modern" PC again.
Reply 41468 of 57606, by luckybob
won a few auctions on ePay the last week. A saved search finally erupted that i've long forgot about. Hard drives! for the IBM PS/2 system. 7 pictured, another 4 are on the shelf, and I couldn't be bothered to get them. They all look the same anyway.
And one oddball ST-225 for a total of 12.
Reply 41469 of 57606, by Kahenraz
Hard drives is one thing I do not collected. I am very happy with the absolute silence and zero latency that solid state provides.
I remember being fond of it as a kid because it sounded very techy. As I've gotten older the sound has become more of nuisance for me.
I'm glad to see them being put into collections regardless. Just not mine.
Reply 41470 of 57606, by appiah4
Kahenraz wrote on 2021-12-15, 07:26:
Eh.. Solid state drives are fine for OS that does not utilize swap space much such as DOS, OS/2, Linux or OS that knows how to handle them such as Windows Vista and onwards.
However, for Windows 95 through and including XP they are a very shitty option IMO.
Reply 41471 of 57606, by Nexxen
Vynix wrote on 2021-12-15, 00:49:
S3 + Polka audio! 😀
One pin fell off and I replaced it with a copper staple. Works wonders.
It wasn't made with the best materials.
There's the issue of bios not recognizing speedstep correctly, but works with model with dock station connector. Replacing the cpu is really tedious.
Enough ranting, I used it a lot and never got disappointed.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
"One hates the specialty unobtainium parts, the other laughs in greed listing them under a ridiculous price" - kotel studios
Bare metal ist krieg.
Reply 41472 of 57606, by luckybob
Oh, you haven't had the pleasure of dealing with IBM PS/2 computers! These drives are TOTALLY INCOMPATABLE with ANY other system other than the 1 or 2 they were designed for. Case in point, the Ibm model 25/30. There are exactly TWO options for hard drives on those systems. The original PROPRITARTY 20/30 mb hard drive, or a special card that takes one of your TWO slots. (well three in the 30, but still) To say nothing of how these drives are RELIABLY un-reliable.
There are NO options for SSD drives in PS/2 machines. Nobody has made an adapter afaik, there are about 4 kinds of these drives and they share connectors. Meaning, you can have a 30mb drive that FITS into the model 30, but it doesnt work because its for the 55.
its MADDENING.
Reply 41474 of 57606, by HanJammer
bjwil1991 wrote on 2021-12-15, 08:30:
All real computers have mechanical hard drives.
More like "all real vintage PCs". I use CFs mostly for ease of moving files between vintage hardware and modern PC. But I still usually add mechanical HDD because of all the sweet noises it makes 😁
Reply 41475 of 57606, by GigAHerZ
HanJammer wrote on 2021-12-15, 08:38:
Same here, i use mainly CF cards - my heart just doesn't allow me to use mechanical stuff just for my own fun... They'll die eventually, and my joy doesn't need to help speeding it up. 😀
A little about software engineering: https://byteaether.github.io/
Reply 41476 of 57606, by Grzyb
"CD2CD" suggests some Compact Disc duplicator...
and "Formats Unlimited, Inc." can be found on this list - http://discdupe.org/i/memberslist-by-country.html
Nie rzucim ziemi, skąd nasz root!
Reply 41477 of 57606, by TrashPanda
luckybob wrote on 2021-12-15, 08:09:
Oh, you haven't had the pleasure of dealing with IBM PS/2 computers! These drives are TOTALLY INCOMPATABLE with ANY other syste […]
its MADDENING.
You gotta hand it to IBM, they for sure loved their proprietary hardware back in the day, it does surprise me no one has attempted to get an adaptor working there must be plenty of documentation around for the PS/2 HDD format.
Reply 41478 of 57606, by appiah4
appiah4 wrote on 2021-12-15, 06:43:
Right.. So the man just messaged me and let me know, for the sake of being honest, that his son informed him that the 4870X2 'overheats'.. Whatever that means. I'd guess that one is defective, which isn't surprising. I think a lot of those cards failed over the years.
Reply 41479 of 57606, by ChrisK
Not exactly collector's wet dream but hey. Unfortunately most of them require some severe cleaning and pin correction work. Guess I'll have to dip them in some IPA over night to get rid of this...smell.
RetroPC: K6-III+/400ATZ @6x83@1.7V / CT-5SIM / 2x 64M SDR / 40G HDD / RIVA TNT / V2 SLI / CT4520
ModernPC: Phenom II 910e @ 3GHz / ALiveDual-eSATA2 / 4x 2GB DDR-II / 512G SSD / 750G HDD / RX470
