Reply 420 of 29883, by dogchainx
- Member
I'll have to post pictures later....but I just refurbished an ORIGINAL GATEWAY 286-16Mhz system. This is such an old Gateway system that it looks like an IBM clone, has the serial number hand written in pen, and the only way to say it is a Gateway system is the little case badge, the infamous "G". I have a few Gateway 2000 486 and Pentium systems, but never seen an original 286 Gateway. Not sure if its a rare collectors item, but its cool to behold Gateway's beginnings.
It had an old EGA/CGA card in it (EGA probably?) but don't have an adapter to check it. But I did plug in an old Cirrus Logic ISA card and the system booted up. There was a massive battery leak all over the mainboard, but after a VERY CAREFUL application of acetic acid and isopropyl alcohol and a THOROUGH drying, it boots up just fine except the clock says it doesn't work. Maybe I need to rework the battery backup I hooked up.
386DX-40MHz-8MB-540MB+428MB+Speedstar64@2MB+SoundBlaster Pro+MT-32/MKII
486DX2-66Mhz-16MB-4.3GB+SpeedStar64 VLB DRAM 2MB+AWE32/SB16+SCB-55
MY BLOG RETRO PC BLOG: https://bitbyted.wordpress.com/
