Reply 420 of 745, by MAN-biker
So, there is no REAL differences with official 1.0.3?
Games' collection 1983-2017. Nickname MAN-biker is registered!
Black Sect Remake (AGS) - Russian version
Lands of Lore: The Throne of Chaos [CD] - Russian version
Warcraft Adventures: Lord of the Clans - Full walkthrough
Reply 425 of 745, by citrixscu
Interesting. So I pay $125 up front for something to support Roland, as I've been waiting for this since my SCB-55 broke in like 1997. Then I pay another 19.95 per month since standalone versions are lagged. Sweet!
Reply 427 of 745, by citrixscu
Ah well. I don't trust the source of the other channels. I'll try writing Roland support but I feel I know what the answer will be. I suppose 1.06 is fine for the minimal DOS gaming I do. Definitely not worth paying again for another version.
Reply 429 of 745, by citrixscu
KainXVIII wrote:
M&M World of Xeen now works with right instruments for sound effects, i think..
Really? Can you elaborate on that a bit? WOX is one of my all time favorites and I play it frequently. I've been using SC VA with Falcosoft Midiplayer4 to enable CTF. Is it possible to test whether the 1.06 version of SC VA is playing correctly with WOX? Cheers.
Reply 430 of 745, by James-F
Capital tone fallback has NOT been fixed and will never be, because it's not part of the hardware.
And no, SC-55 drum velocity has not been fixed either.
Reply 431 of 745, by KainXVIII
So its capital tone fallback fix this issue? I also enabled this fix in FCMP (frankly don't know what IS CTF 😊 )
But i can record some gameplay from Swords of Xeen with RSC 1.10 for example, if you want.
Reply 434 of 745, by MAN-biker
Roland User wrote:
James-F
Yes , this cracked version ) but working without install and workin on Windows XP )
Working in XP?!
All versions of SCVA I have tested DONT work in WinXP (no sounds).
What about old Edirol VSC (5 mb vsc.dll)? I have tested it again yesterday and seems it sounds like SC-55 (cymbals at DOOM E1M1 from 9th sec.).
Reply 435 of 745, by Falcosoft
Working in XP?!
All legitimate versions of SC-VA work in XP but only in trial mode. So the 10 min/session restriction is active, but the 14 day limit is not (most likely because of the activation component's incompatibility).
Edit:
SC-VA under XP:
https://youtu.be/Z9T_BdqT60A
Edit 2:
You should not install it under XP, just use the '...\Roland\Sound Canvas VA' folder's content of your legitimate copy.
Website, Facebook, Youtube
VST Midi Driver Midi Mapper
Reply 436 of 745, by Roland User
Falcosoft
In version 1.0.6 and above damaged sccore.dll if rewrite this file use old file of SCVA 1.0.3 - all worked )
Please , share the normal version of the file sccore.dll of version 1.0.6 and above. This file - sound bank )
Reply 438 of 745, by Falcosoft
I do not understand why and what I should share.
On Roland's website the non-cloud downloadable version is still v1.0.3.
It could be deceptive that the installer's version is 1.1.0.0, but the content is still the old version 1.0.3.
https://static.roland.com/assets/media/zip/sc … a_win_trial.zip
