AMD K6 3DMARK, aiming for stars.
Reply 422 of 560, by Necrodude
Skalabala wrote on 2022-05-02, 08:48:
That is a good result. What is your setup?
ASUS p5a rev 1.04
AMD K6-3+ 400@616mhz
128mb PC133 CL2
Geforce2 Ti 250gpu/440mem
Win98 SE
DX7. nvIdia 7.76 drivers.
Ali agp 1.9 something drivers.
Lots of tweaks.
CTU, wpcred amongst others
Fastest settings in bios.
AGP fast write is off at the moment. Agp 1x for stability reasons.
Reply 423 of 560, by Necrodude
Raised the bus speed to 115. 630mhz
Behold
Reply 425 of 560, by Necrodude
Skalabala wrote on 2022-05-04, 07:12:
You did it! Congratulations! From 4832 to 5171 with only 16mhz extra 😁
So you are number 2 at the moment! that's so awesome!
Thank you.
The next goal is to get the computer 100% stable at that speed. It is rock solid at 616mhz. 24h prime95 and 12h memtest stable.
Reply 426 of 560, by bloodem
Necrodude wrote on 2022-05-04, 12:24:
I have 3 x Asus P5A boards, and only one is stable at FSB 115. The other two are only stable at 112MHz and 106MHz respectively.
Try and disable the onboard/external cache (performance will be worse with it disabled) and see if it's stable after that. If it is, then this means the cache is unstable at this frequency and... there's nothing you can do, really, except maybe replacing the cache chip (4ns EliteMT chips seem to work very well at higher frequencies).
You can try and increase VIO, but that will probably have no effect when it comes to the onboard cache stability.
Current PC: Ryzen 7 5800X3D
Backup PC: Core i7 7700k
Reply 427 of 560, by Necrodude
bloodem wrote on 2022-05-04, 14:22:
I have 3 x Asus P5A boards, and only one is stable at FSB 115. The other two are only stable at 112MHz and 106MHz respectively. […]
Thanks! 😀
Reply 428 of 560, by chrismeyer6
This is a shot in the dark but would adding heatsinks to the cache chips help them with stability at higher clocks?
Reply 429 of 560, by bloodem
chrismeyer6 wrote on 2022-05-04, 16:54:
Definitely not. They are barely warm to the touch anyway... 😀
Reply 432 of 560, by chrismeyer6
Skalabala wrote on 2022-05-04, 21:35:
chrismeyer6 wrote on 2022-05-04, 18:16:
Like I said shot in the dark
I have a sync on the clock generator 😀
That's a good idea on some motherboards they can run warm when overclocking.
Reply 433 of 560, by Necrodude
What does it do? How does it work? Pictures? 😀
Reply 434 of 560, by bloodem
Necrodude wrote on 2022-05-05, 09:06:
I think he meant "sink", as in "heatsink" (which I'm guessing you know what it does). 😁
Reply 435 of 560, by Necrodude
bloodem wrote on 2022-05-05, 11:09:
Oh.... I thought he was talking about some sort of modification..
Reply 436 of 560, by Necrodude
Here is my WCREDIT settings autoloaded by WPCRSET. The motherboard is a ASUS P5A rev 1.04
I did some more wpcredit tweaks and broke 5k in 3dmark200 at 616mhz. Thoose new settings gave me another 200 points
Reply 437 of 560, by Necrodude
Me and my friend G3virus tried the L2 cache mod on newly bought k6-2+ 570 cpu:s. Sadly we got cpus from a bad batch, and they didnt work at all with the mod.
However, G3virus delided the cpus, replaced the IHS with a copper based IHS and used liquid metal between the die and the copper IHS.
That was a golden combo. The k6-2+ 570 is 24h prime95 and 12h memtest stable at 672!!! MHZ.
The other k6-3+ 400 is rock solid 100% stable at 616mhz
The green stuff on the cpu is conformal coating.
    1.25 MiB
    989.1 KiB
    892.89 KiB
    1.4 MiB
    1.71 MiB
Reply 438 of 560, by Necrodude
G3virus also recapped my motherboard. So it works really nice these days.
The copper IHS is from newer AMD cpus that we butchered.
    1.87 MiB
    1.08 MiB
    1.04 MiB
    1.24 MiB
Reply 439 of 560, by Sphere478
Freakin awesome!! Is the increased height an issue?
I was pondering trying to get cnc copper replicas made of the oem spreader. I have a spare lid I can send off.
What cpus are those from? Did you have to shorten or modify them at all? I see you sanded them to the copper on top and bottom perimeter.
Btw idk if you saw my report about recent cpus I’ve modded but I keep getting failed super pi runs on multiple systems. I can’t figure out why. But the cpus are stable in everything else. What’s particularly interesting is that it is happening on my OEM 550 3+. So I’m convinced the cpus aren’t at fault. I’m still unclear what the issue is though. Maybe software, maybe other hardware. Unsure. But it’s on multiple systems.
Re: SUCCESSFUL K6-2+ to K6-3+ Full Cache Enable Mod I added this to the k6 mod guide btw 😀
Sphere's PCB projects.
