Reply 420 of 499, by DosFreak
- l33t++
Amazon Prime Gaming
Gravitar Recharged (EPIC)
Epic
Areian_Knight's Never Yield
Amazon Prime Gaming
Epic
I'm glad that Amazon has been including more remakes of classic games lately. For me, that's much better than all of those hidden object games. I don't even bother redeeming those.
Gog.com
Nomads of Driftland
Nomads of Driftland: The Forgotten Passage
DosFreak wrote on 2024-02-29, 18:21:Just checked and Steam isn't required to run the game. […]
I do see libwinpthread-1.dll so it's likely bare minimum Windows XP compatible but if compiled with a newer mingw-w64 then likely just Vista or 7 at a minimum.
It does state the following in the whatsnew but I don't see the older SDL.dll so likely old information or it's just referring to GDI\Windib\<=D3D9
"The original pixel-based SDL1 backend is still supported
for older or more obscure systems."
So, can you install it without Steam? The links I see all refer to running the Steam installers?
I do have the DOS original, so that is not really an issue for me, but I wonder if Steam should be listed as required in the submission I made for Mobygames.
You can't install anything without Steam since Steam "installs" the games, all you get are the files.
For this game just copying the files elsewhere and executing the game works so apparently no installer is needed.
Everything I download from online stores I make a backup of and crack it. Only way to win is not to play since the games are constantly being modified and add/remove features and DRM and OS compatibility.
Unfortunately you have different opinions on DRM, the "crazies" consider having to download the game via the launcher as DRM which I can't wrap my head around. Having to download a game via the launcher is not DRM (it's shitty but it's not DRM). Even if you could download it via ftp/sftps/ftps/http/https (without the launcher) then that should still qualify as DRM in their mind but it isn't, they only consider having to download the game via the launcher as DRM. 🙄
Steam - Space Crew Legendary Edition
Rwolf wrote on 2024-02-29, 18:02:the game is now ported to Windows
Huh? The original open-source project which I linked to above already supports Windows -- only the proprietary release of Star Control II was for DOS, but IIRC, TUQM is based off the 3DO release.
MrFlibble wrote on 2024-03-03, 12:04:Huh? The original open-source project which I linked to above already supports Windows -- only the proprietary release of Star Control II was for DOS, but IIRC, TUQM is based off the 3DO release.
Correct, but there are settings to use the interface and assets from the PC version. More information here: https://wiki.starcontrol.com/index.php/Version_Comparison
Amazon Prime Gaming
*Requires Amazon Prime to acquire or download
Fallout 2 (GOG)
SCARF
Epic
Astro duel 2
As of March 5th, 2024 WarnerBrothers Discovery has 'retired' Small Radios Big Televisions from both Steam and Playstation 4 stores.
Copy & paste link. It will automatically download.
https://fire-face.com/games/SRBT_2016-09-30_1041.zip
It is still $11.99 on the Steam store.
https://store.steampowered.com/app/390040/Sma … ig_Televisions/
I am not sure those kind of links are allowed here...
kolderman wrote on 2024-03-11, 03:44:I am not sure those kind of links are allowed here...
Links to games on the developer’s website aren’t allowed?
That's the website that the link came from 😀
You guys can edit it or delete it if you want to 😀
Oh I thought it was a sharing website link
Why does everybody keep forgetting about IndieGala?
BEEN_Nath_58 wrote on 2024-03-12, 04:56:Why does everybody keep forgetting about IndieGala?
Thanks for reminding me. Just picked up the Tomato Jones freebie over there. Hilarious game.
liqmat wrote on 2024-03-12, 05:35:BEEN_Nath_58 wrote on 2024-03-12, 04:56:Why does everybody keep forgetting about IndieGala?
I guess I will give a weekly visit there from now on
