Reply 4260 of 27685, by Tetrium
Actually found all parts needed for my old camera, these mobile phones are utter crap when it comes to taking pics of hardware components 😵
I hope it will work this time 🤣!
stamasd wrote:
For the past 2 days I have started, and am now part through a project of organizing and sorting my collections (I do collect other things apart from vintage PCs and parts). My basement looks like a battlefield now. I just hope I finish before the beginning of next week.
Looking forward to learning what solutions you came up with 😁
My retro rigs (old topic)
Report spammers here!
Reply 4261 of 27685, by candle_86
Trying to figure out why my K6-3 wouldn't load windows after installing a 320gb SATA drive for storage
Reply 4262 of 27685, by Bancho
Started working on my WinXP machine today. Very much a work in progress. Installed Windows XP SP3 and will start testing this week.
Abit AN8 Ultra 939 Motherboard
AMD Athlon x2 4400 Toldeo (1mb cache)
1gig Geil PC3500 DDR Ram (2x512mb)
Nvidia Geforce GTX 260
Aureal SQ2500 A3D Sound Card
Sound Blaster Audigy 2 ZS with front panel
36gig WD Raptor HD
Coolermaster 210 Case.
I need to tidy up the cabling, buy a new PSU as the current one is a cheap shit one, and get a new CPU cooler and case fans.
Reply 4263 of 27685, by Mr_ppp
After failing miserably as a teenager to get my head around configuring lan networking for dos games (Google wasn't around to help!) I finally thanks to the internet understand how ipx networking, odi drivers etc work and have successfully configured all my pc's to be able to do lan gaming, already tested with Doom and Rise of the Triad 😀
I even surprised myself getting some pci cards to play ball as well as the older isa ones 😎
Reply 4266 of 27685, by brassicGamer
Yes LAN gaming. That's my next project.
So after recapping the 7600gs pair i got artifacts. Does this mean the cards are screwed fundamentally or is my soldering crap?
267.22 KiB
313.6 KiB
Reply 4267 of 27685, by Tetrium
The GF7 started using this new solder, right?
It's the main reason I kinda avoid any passively cooled GF7s, as usually only baking will help and I don't feel like buying an already baked GF7 which will likely start having problems (again) after a short while.
I'm glad I added active cooling to both of my GF7's when I got them new, I do really like these cards, very similar to GF6800 when it comes to performance and compatibility.
Reply 4268 of 27685, by ODwilly
Attempting to survive a 15 day work week. On day 9 and just about tapped out. Blah
Reply 4269 of 27685, by Imperious
Did some retrobrighting. My original MsMouse USB/PS2 and the front case of my AT case which houses my 486. I forgot to take a before photo of the case
but it was about as yellow as the cdrom drive.
This is 5 hours in the Winter Sun here in Brisbane Australia. I reckon if I tried this in the summer the plastic would all melt.
    99.12 KiB
    171.88 KiB
    158.73 KiB
Reply 4270 of 27685, by PhilsComputerLab
Played some Half Life on a 3dfx Banshee and A3D sound at 640x480. I forgot how arg these old games. I play on easy and die all the time 😊
YouTube, Facebook, Website
Reply 4271 of 27685, by clueless1
Awesome game. 😀 I have the original disc and played it awhile on my Win98 install. Plays and installs so much better than trying to make it work on XP!
I've been benchmarking my two DOS PCs with Wolfenstein 3D timedemo downloaded from Ekb's thread. It seems to be the only timedemo that can bridge the gap between 286's and faster processors and is a lot less painful than Doom to run on slow configurations. 🤣.
Finished the evening by doing some grinding on my Lands of Lore game. Really good "lite" RPG.
Reply 4272 of 27685, by PhilsComputerLab
It is an awesome game. But I'm not used to the difficulty and the mazes 😁 Guess I got used to the modern hand-holding type games 🤣
Reply 4273 of 27685, by brassicGamer
Well the bake seems to have worked on the 8800:
409.58 KiB
And man that needed some baking. So maybe that's the higher temp solder because i did the 7600s at the same temp - all the caps I had just replaced fell out and cooked! I guess i should have waited until after the bake to fit them. The other components that aren't surface mounted also fell off. Ah well at least i know the reflow worked. If the artifacts were caused by the BGA joints i should be in business after resoldering the rest
Reply 4274 of 27685, by FaSMaN
Spent the entire day rediong the win95 and win98 installs on the P3 V2Sli rig, the Windows 95 setup went corrupt after updating the display drivers too high, my own fault that I made worse trying to figure out why the newer drivers didnt work, the Win98 install had a horrid bug after installing unofficial sp3 which would intermittently prevent explorer from displaying all the icons.
Reply 4275 of 27685, by GuyTechie
I wonder if it's better to just leave Win 98 SE unpatched.
Reply 4276 of 27685, by FaSMaN
I think it boils down to two different scenarios, if its just for retro gaming from time to time I think unpatched is better, but for a power users who wants to brag about still being on windows 98 and making it do things it was never intended for its better to patch 😀
This is the first major problem I have encountered with the patch tho.
Reply 4277 of 27685, by Cyrix200+
Testing and blanking all my drives with my new USB to IDE&SATA gadget. Works like a charm!
I have found 3 broken drives already, what do you guys do with those? Just throw em out? Rip out the magnets? Any fun experiments?
1982 to 2001
Reply 4278 of 27685, by FaSMaN
I just Run HDD Regenerator from within hirens, sometimes you can get lucky and its just a few bad sectors, so far its saved atleast two of 120GB HDDs , the ones it couldnt went for recycling 😒
Reply 4279 of 27685, by oeuvre
IDE&SATA to USB adapters are a life saver when it comes to working with older PCs... I pre-format the drives and then put the drivers, updates, and program + game installers on there for whichever OS I plan to install on that drive beforehand and then plug and chug into the older machine. Saves a lot of time.
