Reply 440 of 554, by Spikey
- Oldbie
DracoNihil wrote on 2024-07-28, 04:38:What I don't understand about the infamous "GM.DLS" is that, after hearing a real SC-55 and this emulator and then looking at th […]
zaphod77 wrote on 2024-07-28, 03:54:That is a low quality sc55mkII (mostly) sampleset. and not suitable for use in an actual SC emulation.
What I don't understand about the infamous "GM.DLS" is that, after hearing a real SC-55 and this emulator and then looking at the ROMs you have to use... how is it that "GM.DLS" is the filesize that it is yet it seemingly doesn't have all of the PCM samples?
The combined size of both "waveroms" is 3 MB and "GM.DLS" is 3.3 MB so I don't understand how most of the instruments in that DLS don't have all of their PCM samples present, or is there something else going on in the SC-55's PCM chip that is producing the sounds I don't hear "Microsoft Synthesizer" doing.
For context: I'm talking about the "String Ensemble" program. Especially when played at the lower (below "Middle C") octaves.
Depends how the samples are compressed. Roland uses 2:1 companding so the true size is 6 or so MB. Although minus the MT-32 sounds (1/2 MB), it's 2/4.
So 3.3MB, depending what level of compression is present, may not be the full 4-6 MB.
But the key reason it sounds garbage is the lack of effects. Roland's warm reverb and thick chorus absolutely transform the SC-55 sound.
