Reply 45180 of 57465, by NyLan
Kahenraz wrote on 2022-06-15, 13:13:
Let's keep it civil. We don't want to risk this thread getting locked. We would have to start all over again! […]
NyLan wrote on 2022-06-15, 11:42:
I don't know how the situation is outside of Europe, but here it's very difficult to get a "well working" IDE DVD Player in Glorious Beige. I bought lot of IDE players, writers, etc... very cheap but I'm always having issues or noises. And I can't stand putting a black one in my retro rigs.
So... when I found a new old stock of SH-D162D I decided to buy a box with 10 of them 😆
I feel you. I've been using some of my disc drives lately and found that several have issues with the tray ejecting (or not). Replacot the belt didn't work, so maybe it's a motor thing. These are not replaceable, in my experience.
Just this past week, I thought that I had a faulty disc in a machine I was bulding, but it turned out that that disc drive could read the disc sometimes, and was able to play music, but would fault when copying data or trying to make an image.
This was a very good purchase. The drives I have left are are black.
Yep Tray ejection is one of the common issue I'm facing. Recently I also got an issue reading an official CD... clean as new but not working and some wierd noises.
Should be good for a while now 😆
My Intel SE440BX-2 Intel's website Mirror : Modified to include docs, refs and BIOSes.
Proud owner of a TL866 II
Personal GitHub
Reply 45181 of 57465, by HanJammer
This superclean Amiga 2000 with keyboard (not that clean)... I didn't knew what to expect inside, and it turned out it has no corrosion at all and 2 Zorro cards (not really something interesting but I will gladly check how Oktagon controller compares to A2091 and GVP cards... Also somebody used hp IDE CD-ROM to fill the empty 5.25" bay ;d - apparently they removed SCSI HDD and optical drive...
Reply 45182 of 57465, by Shnur
TrashPanda wrote on 2022-06-15, 14:58:
It originally came from the seller with an earlier revision of the EVGA bios which I flashed back to stock, it was a couple of y […]
It originally came from the seller with an earlier revision of the EVGA bios which I flashed back to stock, it was a couple of years later when I got my hands on some 4gb 1.8/1.9v DDR3 sticks that I started using a modded BIOS.
No shade on ASUS but their stock bios had a ton of issues and weird limitations due to being unfinished, I’m guessing their devs were not that familiar with the 790i chipset.
I’ve had no show stopping problems with the EVGA bios, less issues than the stock ASUS one.
I can understand the feeling of using a bios not intended for the board, it’s certainly not something I would suggest doing if there was an ASUS bios for it.
You could grab a cheap 790i Dell board, they also work with the EVGA bios and generally go for cheaper prices than other versions.
Then you can keep the ASUS board unmodded and not risk bricking it.
IDK, i never had any troubles with this particular board, and after reading hundreds of reviews for different 790i boards recently - Striker II Extreme is considered as top choice for OC after Digital PWM board. XFX and HP are two Nvidia reference boards and have identical board layout and components on the board, Asus in opposite has customized version of 790i board with improved power management and providing water cooling support out-of-the-box. Thats why "alien" BIOS could potentially harm the board due to incompatibility of components\signals\voltages.
In terms of BIOS Asus also provides much better OC capabilities in their default menu options. There is a lot of garbage in Asus BIOS (like multiple language support and pretty large logos), but in general it's pretty advanced development for that time. ACPI tables are almost twice the size compare to XFX BIOS, Crash Free Bios Update, CMOS Reset Hardware button, OC profiles in BIOS and other pleasant stuff.
Asus:
CBROM32_1.99.exe V1.99 [02/12/2010] (C)Phoenix Technologies 2001-2008
******** 1402_xeon.BIN BIOS component ********
No. Item-Name Original-Size Compressed-Size Original-File-Name
========================================155E2h(85.47K)==gamay.BIN=============== 0. System BIOS 20000h(128.00K)
1. XGROUP CODE 0F550h(61.33K) 0ABC8h(42.95K) awardext.rom
2. ACPI table 087EEh(33.98K) 0308Eh(12.14K) ACPITBL.BIN
4. YGROUP ROM 0D0F0h(52.23K) 06195h(24.40K) awardeyt.rom
5. FNT1 ROM 056FEh(21.75K) 03E4Dh(15.58K) font1.awd
6. FNT2 ROM 05852h(22.08K) 02CCFh(11.20K) font2.awd
7. FNT3 ROM 039C6h(14.44K) 0213Bh(8.31K) font3.awd
8. GROUP ROM[ 0] 0B630h(45.55K) 0433Bh(16.81K) _EN_CODE.BIN
9. GROUP ROM[ 1] 0CA00h(50.50K) 04981h(18.38K) _FR_CODE.BIN
10. GROUP ROM[ 3] 0CAC0h(50.69K) 04ADEh(18.72K) _GR_CODE.BIN
11. GROUP ROM[ 8] 0AB70h(42.86K) 04458h(17.09K) _B5_CODE.BIN
12. GROUP ROM[10] 0A8B0h(42.17K) 04468h(17.10K) _GB_CODE.BIN
13. GROUP ROM[11] 0C090h(48.14K) 04B0Ch(18.76K) _JP_CODE.BIN
14. BIOSF0 01F10h(7.77K) 01475h(5.11K) _DMI.BIN
15. BIOSF9 0F360h(60.84K) 005BDh(1.43K) _RT.BIN
16. BIOSF7 011C0h(4.44K) 00C76h(3.12K) _Xsetup.BIN
17. OEM0 CODE 0BD40h(47.31K) 00996h(2.40K) BGROUP.BIN
18. OEM2 CODE 00E00h(3.50K) 00711h(1.77K) EC.BIN
19. PCI ROM[A] 0CE00h(51.50K) 07D15h(31.27K) NVRAID.ROM
20. PCI ROM[B] 0E000h(56.00K) 07519h(29.27K) NVPXES.NIC
21. PCI ROM[C] 08000h(32.00K) 0457Fh(17.37K) JMB363.bin
22. BIOSF6 0E32Eh(56.79K) 079E4h(30.47K) EZFLASH.EXE
25. GV3 02DD1h(11.45K) 01077h(4.12K) PPMINIT.ROM
(SP) NCPUCODE 13000h(76.00K) 13000h(76.00K) NCPUCODE.BIN
(SP) HOLE0 55h(0.08K) 55h(0.08K) MPLLWAR.BIN
(SP) HOLE1 1A60h(6.59K) 1A60h(6.59K) ROMSIP.BIN
Total hole area space = 10000h(64.00K)
Total compress code space = CD000h(820.00K)
Total compressed code size = AA3FDh(681.00K)
Remain compress code space = 22C23h(139.03K)
*** NVMM 4.083.9610/02/08 ‼♥ * Start Offset => 0, End Offset => 9800 ***
** Micro Code Information **
Update ID CPUID | Update ID CPUID | Update ID CPUID | Update ID CPUID
------------------| SLOT1 0B 0001067A-| SLOT1 0F 00010676-| SLOT2 0F 00010676SLOT1 0B 0001067A
PPGA 0F 00010676| SLOT1 0F 00010676 | PPGA 0A 00010677 | SLOT1 5D 000006F2
SLOT1 D0 000006F6| SLOT2 D2 000006F6 | PPGA 6A 000006F7 | SLOT1 6B 000006F7
SLOT1 BA 000006FB| SLOT2 BC 000006FB | PPGA BA 000006FB | SLOT1 BC 000006FB
SLOT1 A4 000006FD|
XFX:
******** 811N3P09.BIN BIOS component ********
========================================140E4h(80.22K)==811N3P09.BIN============ 0. System BIOS 20000h(128.00K)
1. XGROUP CODE 0FB80h(62.88K) 0A43Ah(41.06K) awardext.rom
2. ACPI table 056AEh(21.67K) 01F7Dh(7.87K) ACPITBL.BIN
3. YGROUP ROM 0CD20h(51.28K) 056ECh(21.73K) awardeyt.rom
4. GROUP ROM[ 0] 080F0h(32.23K) 032DAh(12.71K) _EN_CODE.BIN
5. SETUP0 01F30h(7.80K) 00CC5h(3.19K) _ITEM.BIN
6. BIOSF0 021B0h(8.42K) 0154Bh(5.32K) _DMI.BIN
7. OEM0 CODE 0CD50h(51.33K) 01231h(4.55K) BSMICODE.ROM
8. PCI ROM[A] 0CC00h(51.00K) 07C1Ch(31.03K) NVRAID.ROM
9. PCI ROM[B] 0E800h(58.00K) 07961h(30.34K) NVPXES.NIC
10. PCI ROM[C] 08000h(32.00K) 04576h(17.37K) JMB363.BIN
11. OEM1 CODE 00A90h(2.64K) 005F7h(1.49K) PMU.BIN
12. GV3 026BDh(9.68K) 00D98h(3.40K) PPMINIT.ROM
13. Flash ROM 0C13Ah(48.31K) 06896h(26.15K) AWDFLASH.EXE
14. OEM2 CODE 000EBh(0.23K) 000DFh(0.22K) VERB.ROM
16. OEM3 CODE 04AC9h(18.70K) 01289h(4.63K) OEMINI.ROM
(SP) NCPUCODE 36400h(217.00K) 36400h(217.00K) NCPUCODE.BIN
(SP) HOLE1 233Ch(8.81K) 233Ch(8.81K) ROMSIP.BIN
Total hole area space = 20000h(128.00K)
Total compress code space = BE000h(760.00K)
Total compressed code size = 807D6h(513.96K)
Remain compress code space = 3D84Ah(246.07K)
*** NVMM 4.093.8409/04/09 ‼♥ * Start Offset => 0, End Offset => ad00 ***
------------------| PGA423 2C 00000F25-| PGA478 37 00000F27-| PGA478 2E 00000F29PGA478 2B 00000F25
PGA478 0B 00000F65| SLOT1 04 00000F64 | PGA478 0F 00000F62 | PGA478 07 00000F61
SLOT1 05 00000F60| SLOT1 04 00000F4A | SLOT1 03 00000F49 | SLOT1 03 00000F47
SLOT1 06 00000F44| SLOT1 05 00000F43 | SLOT1 03 00000F42 | SLOT1 17 00000F41
SLOT1 02 00000F37| SLOT1 17 00000F34 | SLOT1 0C 00000F33 | SLOT1 0A 00000F32
SLOT1 0B 00000F31| PGA478 12 00000F30 | SLOT1 A1 000006FD | SLOT1 B6 000006FB
SLOT1 82 000006F9| SLOT1 C6 000006F6 | SLOT1 33 000006F5 | SLOT1 33 000006F5
SLOT1 25 000006F4| SLOT1 26 000006F4 | SLOT1 11 000006F1 | SLOT1 56 000006F2
SLOT1 05 000006F0| SLOT2 05 000006F0 | SLOT1 05 000006F0 | SLOT1 32 00010661
MOBILE 35 00010661| SLOT1 04 00010660 | PPGA B6 000006FB | PPGA 66 000006F7
SLOT2 06 00010671| SLOT1 06 00010671 | PPGA 06 00010671 | PPGA 04 00010674
SLOT2 04 00010674| SLOT1 04 00010674 | PPGA 0B 00010676 | SLOT2 0B 00010676
SLOT1 0C 00010676| PPGA 05 00010677 | SLOT1 07 0001067A | SLOT1 06 00010671
SLOT1 04 00010674| SLOT1 06 00010676 | SLOT1 06 00010671 | SLOT1 05 00010674
SLOT1 0C 00010676| SLOT1 04 0001067A |
Reply 45183 of 57465, by Shnur
TrashPanda wrote on 2022-06-15, 16:30:
Kahenraz wrote on 2022-06-15, 15:25:
Maybe your memory issue had to do with the density of bank arrangement. This was always a problem with SDRAM. I'm not sure about DDR though. You could also try lowering the timings. Some boards won't work maxed out at the fastest speeds.
Nag these were some of the first boards to support DDR3 and it wasn’t always implemented for 16gb to function right. This was back when the north bridge had the memory controller and wasn’t particularly powerful, at best if you got 16gb to work then it wouldn’t clock past pc3 8500 speeds.
8gb works perfectly however.
The problem is purely in BIOS implementation corner. Basically none of manufacturers were ready for modern-world RAM capacity at that time, so the maximum RAM per slot was considered to be 2 GB, or 8 GB in total for 4 slots (dual channel). Chipset itself supports more than 8gb of RAM, which has been proved by many XFX board owners with specific revisions of BIOS used, so the limit is basically hardcoded in the System BIOS during RAM initialization routine.
In Asus case during my investigation i found that BIOS doesn't post with more than 10 GB of RAM because of the memory remap feature. NVMM module in BIOS sets the TOM (top of main memory) register correctly after analyzing available RAM, but later Remap routine is setting REMAPBASE\REMAPLIMIT registers incorrectly and PCI devices (including SATA controler) can't initialize which leads to failed POST procedure and boot-loop. I'm very new to bios modding and currently only studiying guides on relevant topics, so those are the only findings so far. 😀
Reply 45184 of 57465, by TrashPanda
Shnur wrote on 2022-06-15, 23:03:
IDK, i never had any troubles with this particular board, and after reading hundreds of reviews for different 790i boards recent […]
Asus:
SLOT1 A4 000006FD|
XFX:
What I found with the ASUS board was that it was picky about DDR3 modules more so than the EVGA boards I have, perhaps its just my board, I dont know the history of it from the previous owner and since it came with an EVGA BIOS its possible it had been thrashed with some overclocking. I cant really complain as I was lucky to even get it at the time for the price I did as any that hit eBay either sold fast or went for stupid amounts of money. But since its working and doesnt appear to have any issues with the EVGA bios I dont feel the need to mess with it any further. (I'm actually expecting it to not like being in storage, had a number of other parts die from caps while stored)
I should perhaps dig the Digital PWM board out of its box, I dont really like to use that board much due to its rarity and the fact it is one of the more valuable boards I own but it might be worth firing it up and seeing if its still kicking.
I really do hope that you find a way to get an ASUS BIOS to post and work with 16gb, it would be nice to have a working one since as you said all the extras are very nice to have.
On a side note that is in no way related to ASUS
https://www.youtube.com/watch?v=kCCXRerqaJI
Now this is what I really enjoy seeing one dude use retro hardware for something amazing.
Reply 45185 of 57465, by Radical Vision
Found these piles of crap... Then saw the Bansheee. Got them for 12 euros...
K7 2.6/ NF7-S/ HD3850
Cmq P2 450/ GA-BX2000/ V2 SLI
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 45186 of 57465, by Kahenraz
That's a Skywell Magic TwinPower. But it's a universal AGP connector. I've never seen that before on a banshee, or any 3Dfx card for that matter.
https://3dfx-banshee.de/banshee-cards-overvie … ic-twinpower-ac
I thought I was the only one. 😀
Interesting case of someone cutting a voltage notch into an AGP card
Reply 45187 of 57465, by imi
Kahenraz wrote on 2022-06-16, 12:16:
I think that's just the slot bracket of the I/O board laying on top of it 😁
Reply 45188 of 57465, by Radical Vision
imi wrote on 2022-06-16, 12:55:
Ahahah 🤣 u are right tho....
KEKW ...
IBM PC365
Cmq DeskPRO 486/33
IBM PS/2 Model 56
SPS IntelleXT 8088
Reply 45189 of 57465, by PcBytes
If you got the Aristo board as well, that's quite a bit of a score. Albeit PCChips, that thing actually has an genuine 440LX chipset, and the CMI8330 onboard shouldn't be too bad either. I wonder if the 3dFX wasn't originally paired with the Celeron that's on the Aristo board.
Reply 45190 of 57465, by Kahenraz
Oh, I didn't see that. Haha.
The motherboard is also nice. I don't collect AT boards as a rule, to limit the size of my collection (I won't need to collect the cases as well). I see that this one is a Slot 1 with SDRAM and an AGP slot. Is this a very late or unusual combination? It seems rather desirable.
I like how many expansion slots it has. I think the Baby AT form factor has more than an mATX?
Reply 45191 of 57465, by Gmlb256
Used to have one of these Slot 1 motherboard in AT form factor (which I barely used as I went moved quickly to the Pentium 4 platform at the time) and it had the Soltek brand. It came with an Intel 440BX chipset, was capable of running a PIII-750 without a hitch and didn't have that awful CPU positioning that plagued older platforms.
I only kept the PIII CPU which was eventually used on an ASUS ATX motherboard.
Reply 45192 of 57465, by Kahenraz
I've heard that there is at least one Socket A Baby AT motherboard floating around.
Reply 45193 of 57465, by TheMobRules
Kahenraz wrote on 2022-06-16, 15:30:
Baby AT has up to 8 expansion slots.
Reply 45194 of 57465, by Kahenraz
That's really nice. I love the mATX form factor, but I always wish it had anothrr slot or two. I like being able to use small cases for less often used builds.
I have a particular case, which I love. The PSU is small and hinges over on top of the area right above all of the expansion slots. It's a neat truck that saves a lot of vertical space. It also adds a lot of airflow over any expansion cards that might get extra hot, like an accelerator card.
Reply 45195 of 57465, by pc-sound-legacy
I got a GeForce MX 460 today. I never had one so far, so it is welcome in my collection of AGP cards! I'm curious how much faster it is in comparison with the more common 440?
Reply 45196 of 57465, by TrashPanda
pc-sound-legacy wrote on 2022-06-16, 21:50:
its a slightly higher clocked 440, there is also a MX 480 too which is higher clocked again, there isnt a lot of difference in performance as other factors hamper the cards more.
Reply 45197 of 57465, by Kahenraz
I'm pretty sure that the MX 480 was just the MX 440 with AGP x8 and is slower than the MX 460.
Reply 45198 of 57465, by darry
darry wrote on 2022-05-14, 17:46:
Got an ECS 865PE-A7 REV 1.0 with some 2.8GHz P4 on it and various other items salvaged from a dirty and rusty (on the outside) case . It might become a project to try to get PC/PCI working by tapping signals from the ICH5 southbridge . No idea if a BIOS mod would be required .
No idea if anything works yet. The caps are OSTs and others from the bad old days, but that system had extensive cooling (fans) and what looked like a fan controller, so it might still work, but even so, it's probably only a matter of time before recapping is unavoidable.
Well, I'm pretty much giving up on this board for now . Not even sure it's worth a recap .
Reasons ?
a) I soldered a pin header to the S-IRQ labelled solder point (which I presumed might be PC/PCI) and was able to, AFAICT, get some traction in the ICH5 patched version of setupds with both a YMF724 and a YMF744 . Specifically, S-IRQ tests succeeds with the sb-link cable connected (and fail without the cable connected), but all the DMA tests fail, no matter the channel (maybe that's the reason the connector is named S-IRQ rather than PC/PCI or SB-LINK ?). The fact that the two pins that should be ground actually are at ground initially gave me hope. I tried playing with ICH5 PC/PCI registers (using ru.exe) to try to get it to work, but came up empty (not fully understanding how PCI BARs are supposed to work may be part of the problem).
b) At least one of the caps is bulging and will need to be replaced, along with all the other electrolytics
c) The bone headed idiot (IMHO) who layed out this board thought it would be a good idea to put what look to be two voltage regulators that both get extremely hot between the AGP slot and the first PCI slot AND to put electrolytic caps around them (see point b). Cooling those regs is practically impossible with an AGP card such as an FX 5900XT installed . Replacing the caps would just delay the inevitable (again IMHO).
d) Likely due to points b and c, the board is somewhat unstable and crashes intermittently, among other things (but not exclusively), when running serren.exe from http://rayer.g6.cz/programm/programe.htm
e) In terms of DOS sound card chipsets compatibility, I have tried an AU8830 (works in Doom, but not in Cubic Player, or example), 2 difference CMI8738 variants (no PCM audio, FM works), an ESSE Maestro 2E (only FM works, but have not played with the card's PCI registers as it is noisy as hell), YMF724 and YMf744 cards (FM works, no PCM audio ), a CS4630 based Turtle Beach Santa Cruz (FM works, PCM works perfectly for a few seconds before hard-locking the machine in Doom, for example), a Fortemedia FM801-AU (PCM seems to work, but a bit glitchy at times in legacy mode 2 and FM works fine and 2 different ALS4000 based cards (FM works, but PCM sound like stuttering crap in WBDMA, which is the only mode that works at all for PCM)
Consequently, I might have gotten a bit drunk before ordering
1) An Asus P5P800 (probably pointless as ICH5 based as well) (I am dumb)
2) A MSI MS-6580 (ICH4 based, so no DDMA either and no PC/PCI) (I can be quite the idiot, it seems)
3) An Asus P4S800-MX (I might have sobered up a bit at this point as this one has an SIS963L southbridge which should support DDMA)
I am also considering getting a Trident 4DWave based card (why the hell not ? I own a an example of practically everything else that is PCI and has legacy DOS support, except an EV1935/ Opti 935)
There goes the discretionary budget for the rest of this Summer . 😉
P.S. I have some spare CPU coolers for socket 478 and I am crazy enough to try mounting a socket 775 one on a socket 478 board .
With a hobby like this, who needs chores ?
Reply 45199 of 57465, by smtkr
I've been thinking about getting one of these. Is that dual VGA instead of DVI+vga? Interesting choice from the manufacturer.
