Reply 45940 of 53039, by Thermalwrong
TheAbandonwareGuy wrote on 2022-08-13, 01:19:These caps were full on vented. Like you don't need a PHD in electronics to know caps shouldn't look like THIS: […]
Thermalwrong wrote on 2022-08-12, 23:20:TheAbandonwareGuy wrote on 2022-08-12, 17:38:On a side note, literally just received the G6600. "Works great" yeah I'm sure it did, with the 5 vented capacitors on the front. Obviously was never tested (or at least not within the last decade). Why are there so many dirtbag sellers in the retro computer parts space?
Eh, I don't think they're that bad, folks selling broken from use / worn out stuff is better than sellers that are selling things with crushed cores and loads of missing SMD components.
Really though I think even spotting 'bad fan' / 'bad caps' is a lot of ask of most sellers, but it's nice they're still selling these things rather than putting them out for scrap, especially where there's an obvious fault (that hopefully hasn't lead to worse faults...).
If they were just bulging or hairline vented I would be more understanding but these have gone full blossom. Like this objectively a level of failure you should recognize if your selling electronics in any capacity.
This being said the seller did issue a full refund fairly quickly, so I'll probably still leave positive feedback. I might try to recap this piece of shit at some point, I need to order caps for a 6800GT I've had for years anyways (I hate ordering caps, such a pain)
This is electronics maintenance that I don't think most folks could / would want to do for the price points they're selling at. Eventually everything's gonna be broken like this if it's not cared for / repaired right and the numbers will keep dwindling, more so for cards that were run fairly hard in their lifetime e.g. GF6800 & Radeon 9700/9800. Just, personally I don't think an obvious fault like that is that bad. Much better that than a bad BGA RAM chip, although that could be a resulting fault from running with ruined capacitors.
For bad sellers though - I bought a job lot of old electronics with a mix of 70s PCBs, a PC Chips M919 and a Kapok 6200 laptop's mainboard, the seller only sent me the 70s PCBs, ergh, not so useful to me.
