Reply 480 of 488, by jtchip
ruthan wrote on 2023-06-07, 19:17:You can try to search if this is compatible with AC97.. and if yes try SB-EMU driver.. I opened some datasheet and there is some […]
It's CMI8738. At least I could recognize the C-Media logo on the chip.
You can try to search if this is compatible with AC97.. and if yes try SB-EMU driver.. I opened some datasheet and there is something about SPDF_AC97 register, but it does not have mean that its AC97 compatible device.
Its based on MXPlay which have some Cmedia8738 support.. but this changelog is mess, i dunno if Cmedia support its DOs or WIn related:
https://mpxplay.sourceforge.net/whatsnew.txt // Search for 8738
But text new (PCI) soundcard handlers: from my point of view suggest more DOs than Windows thing..
MPXPlay does support the CMI8738 but SBEMU does not, the cmi8x38 driver is not compiled in. I made a post earlier about audio controllers supported by SBEMU. Whether an audio controller uses AC97 or not is mostly irrelevant for SBEMU, it's whether it supports the audio controller in the first place.
The Asus A8V-X has a VIA VT8251 south bridge with HD Audio controller, SBEMU will probably work with that (I think it's PCI device 1106:3288). Anyway, all that belongs in the SBEMU thread.
