Reply 48960 of 53280, by Minutemanqvs
Haa I still have my HP 48G calculator with all manuals from back when I was at engineering school: https://en.wikipedia.org/wiki/HP_48_series
It was amazing back then, you could transfer files to it via serial cable, share files between calculators using IR and there were even some games.
It has a CPU architecture I never hear of before: https://en.wikipedia.org/wiki/HP_Saturn
Searching a Nexgen Nx586 with FPU, PM me if you have one. I have some Athlon MP systems and cookies.
Reply 48961 of 53280, by Kahenraz
I still have my Ti-83+ Silver Edition from high school as well. I used it up through college where I found a graphing bug. I called Ti to report it and the guy at the call center had a physical copy of all of their supported calculators. He graphed the equation on a couple of the units, confirmed the bug, and that was that.
Reply 48962 of 53280, by lolo799
Minutemanqvs wrote on 2023-04-28, 06:58:
They're still amazing, and you can keep using them, as serial terminals, winamp remotecontroller, serial mouse, for internet access, making music, and so on. There were a lot of games available, and a little demoscene as well.
https://www.hpcalc.org/ is still alive and kicking!
Reply 48963 of 53280, by Minutemanqvs
lolo799 wrote on 2023-04-28, 08:39:
Ahh I'll have a look. I know that at the time it was possible to mod a 48G to a 48GX with more memory. It was very useful for work games.
Reply 48964 of 53280, by Predator99
Surprise box today...some interesting cards:
Network / Modem
Controllers
What is this RAM card for? The POST-card also looks interesting, will dump the ROM later
Heath 286 and IO card with unknown connector
Reply 48965 of 53280, by Predator99
..and Apple II cards
Strange mix but seems to be worth the money I paid...
EDIT: The ROM on the POST-card will not do very much...
Reply 48966 of 53280, by debs3759
Predator99 wrote on 2023-04-28, 19:40:
Good luck with that. As there is no sticker over the EPROM window, you'll be lucky if the data is complete, if it's not fully erased (depends how long it's been in the light with the window open to that light).
Reply 48967 of 53280, by Predator99
debs3759 wrote on 2023-04-28, 19:44:
Yes I noticed that. See screenshot I added above. Does not look like nonsense on the first sight. "55 AA", size of 01 and a Jump in byte 4....think the ROM is OK but theres not too much content...
Reply 48968 of 53280, by weedeewee
ram card for memory upgrade of 512K ibm 286 pcs ?
Cards from a Zenith computer or something, look similar to the ones I posted recently in the found thread. Useless without backplane.
and some nice soundcards too.
oh, about the rom, run it through a disassembler to see what it does.
Do not ask Why !
Reply 48969 of 53280, by andre_6
amadeus777999 wrote on 2023-04-27, 06:01:
HanSolo wrote on 2023-04-26, 10:04:
I'm from Germany. Here I still see CRTs being offered from time to time, but mostly they are too far away to pick them up. But f […]
amadeus777999 wrote on 2023-04-26, 08:02:
I take in what I can albeit space is limited. They are worth a lot to me - not in a monetary sense of course. All screens are "s […]
All screens are "screened"(brightness/color/sharpness) and then rated in a tier system which means that burnt out ones get used first and then discarded - given the phosphor or the electron gun(s) is/are dying. Even putting these ones away hurts a bit as sometimes it's a tasty model, for example, a 22" Iiyama or similar.
Worthier ones are being stored for "service" and some gusto-usage.
Where are you situated - Europe or US? I heard that in some parts of the west Crts are getting scarce... it may be useful to connect the CRT collector's hobby with an official outlet. Something like cooperating with a department for technology or art - this way funds could be raised to keep the screens working.
I'm from Germany. Here I still see CRTs being offered from time to time, but mostly they are too far away to pick them up. But from my observations over the last 3-4 years they are getting rarer. And yet there doesn't seem to be much interest in them because if an ad shows up it doesn't disappear very quickly. (Right now I see a 17" and a 15" being offered since 2 months)
I know that not only Retro-PC-user look for them but also collectors of arcade machines.
I'm not an expert on CRT technology, but what I know is that Sony-tubes become brighter just by sitting unused for years. But that can be fixed by software. The same might apply to the Mitsubishi Diamontron (Iiyama). So maybe you shouldn't throw away the 22" too early. I have one such a problem with a Dell (with Sony tube inside) that I plan to try to repair 'some day'..
Germany is one of the better countries for retro things - big(ger) nation were some people are neat and keep things tidy. I'm in Austria, which is similar but the "market" is way smaller and often less interesting. Yes, Crts still do not get too much love... fortunately or one would have to pay a Lot (more) for them
The IIyama was shot as one of the emitters seemed failing - the picture always had a red tint which did not stem from a bad solder joint. I encountered "brightening" of Sony tubes in an IBM P260 - with the right tools it's just a small service routine. Nonetheless a pesky issue.
Hello, I looked everywhere for your reply, I read it and then totally forgot in which thread it was in!
I even created a new thread to try and obtain the answer, here: Sony CRT TVs and Monitors "breathing" and brightness problem - which caps/parts to replace to fix it?
But I can just delete it and ask here: could you please elaborate on the procedure to solve the "breathing" and brightness issue on Sony CRTs? I have that same problem with a small 1999 Black Trinitron, I adjusted the brightness to mitigate the issue of distorted geometry and it worked, but I assume it will only get worse with age, and that servicing it is inevitable. How did you proceed to do the service? What parts/capacitors did you replace, if that's the case, and if it's the same between Trinitron Monitors and TVs? Many thanks for your help, glad I could finally find your reply!
Reply 48970 of 53280, by rasz_pl
Network / Modem
No modems there, just Arcnet cards pretending to be Ethernet and Modems 😀 Com90c65/UM9065L is Arcnet, so are the Dlink RJ11 ones. 2.5 Mbit/s token ring weirdness that tried to compete with IBM 4/16 Mbit/s Token Ring at fraction of the cost but ultimately lost to Ethernet. Big plus was ability to wire in STAR topology using passive hubs like Apple LocalTalk/PhoneNET. Afaik you can connect two rj11 cards together directly with ordinary telephone cable.
Controllers
Love the vintage POST card.
WD1036S-WX2 Board 1/4" tape controller (IBM PC XT to QIC-36).
fast multimedia av master = AV Master 2000. Mjpeg hardware encoding/video capture at full framerate, bundled with full version of Ulead. Full NLE on a card. $750 when introduced at CeBIT'99, down to ~$550 in 2000. Video Toaster eat your hear out. https://www.youtube.com/watch?v=vqD9iOrbPyI Love oddball stuff like this.
Reply 48971 of 53280, by Predator99
weedeewee wrote on 2023-04-28, 19:59:
0x0000000000000000:  90          nop
0x0000000000000001: 90 nop
0x0000000000000002: 90 nop
0x0000000000000003: E8 14 00 call 0x1a
0x0000000000000006: B0 D1 mov al, 0xd1
0x0000000000000008: EE out dx, al
0x0000000000000009: E8 0E 00 call 0x1a
0x000000000000000c: B0 DF mov al, 0xdf
0x000000000000000e: EE out dx, al
0x000000000000000f: E8 08 00 call 0x1a
0x0000000000000012: FA cli
0x0000000000000013: B0 FC mov al, 0xfc
0x0000000000000015: E6 64 out 0x64, al
0x0000000000000017: F4 hlt
0x0000000000000018: EB FD jmp 0x17
0x000000000000001a: BA 64 00 mov dx, 0x64
0x000000000000001d: EC in al, dx
0x000000000000001e: A8 02 test al, 2
0x0000000000000020: 75 FB jne 0x1d
0x0000000000000022: C3 ret
0x0000000000000023: 5B pop bx
It perfoms some I/O operations then it stops. Nothing very useful. At least the dump is OK.
Reply 48972 of 53280, by Predator99
rasz_pl wrote on 2023-04-28, 22:04:
No modems there, just Arcnet cards pretending to be Ethernet and Modems :) Com90c65/UM9065L is Arcnet, so are the Dlink RJ11 one […]
Network / Modem
Controllers
Thanks for your research! 😀
Indeed, no modems but Arcnet. Maybe I will keep some to play with them. At least some ethernet cards under them...
Reply 48973 of 53280, by amadeus777999
andre_6 wrote on 2023-04-28, 21:16:
Hello, I looked everywhere for your reply, I read it and then totally forgot in which thread it was in! […]
Most of your questions are (way) beyond my expertise.
But when it comes to a Trinitron PC monitor with the brightness issue, the following procedure can be done...
https://www.youtube.com/watch?v=xH4fKpKLkBM
I have some of my stuff stored on the countryside(Crt, cable), so I can't provide much info as I can't test the procedure step by step to verify my memories.
The video should help though. Changing the resistor may not be a good option so better try the cable/software route.
I'll most likely buy a P260 crt in the next 2 weeks, so this should ease "re-hashing" what I did.
Reply 48974 of 53280, by whitepawn
Predator99 wrote on 2023-04-28, 19:41:
..and Apple II cards […]
There are some pal chips on that POST card.They might be protected though.
Very good card.Does it work?
Reply 48975 of 53280, by Standard Def Steve
Yay, it's garage sale season again! Picked up two boxes of promotional flash drives today. They range in size from 512MB - 2GB, and with write speeds barely hitting 2 MB/s, they are pretty much useless these days. But hey, $3/box, plus the fun shapes and colours totally won me over. 😜
Reply 48976 of 53280, by PcBytes
Car boot sale day here.
Got a Medion machine (surprisingly under the Microstar branding) w/ the following specs:
- MSI MS-6747 mainboard
- P4 2.8GHz HT (Northwood)
- 160GB Seagate Barracuda ST3160021A
- Geforce FX5600 XT - what's the deal with the XT? Is it any better than a standard 5600?
- 512MB of RAM which I upgraded to 3.5GB over 4 DDR sticks
- Some funky TV-Tuner + 56k modem combo PCI card
- interesting front panel combo - Multi-Card Reader, USB, Composite, S-Video, USB, 1394, Line in, Out, Mic and Gameport. - also explains the yellow header installed on the 5600.
- Fortron FSP250-60MDN-120 PSU - barely any issue apart from a scorched load resistor and a bulged cap as its consequence - FSP really didn't think it through that much to add a big ass resistor that would cook any traditional cap installed in that place. The rest surprisingly held up very well. Half bridge topology from what I've seen inside.
- Pioneer DVD-RW drive + Ultima DVD-ROM drive
- silver bezel Sony floppy drive that I have little hopes in ever seeing it work again
- Creatix PCI WLAN card, w/ Agere chipset.
Reply 48977 of 53280, by Predator99
whitepawn wrote on 2023-04-30, 16:54:
Yes works and gives a nice firework. Dont know what all the LEDs mean.
Also dont know about the PALs, my Minipro seems not to be able to read them.
Reply 48978 of 53280, by andre_6
amadeus777999 wrote on 2023-04-30, 12:41:
Most of your questions are (way) beyond my expertise. But when it comes to a Trinitron PC monitor with the brightness issue, th […]
I have some of my stuff stored in the countryside(Crt, cable), so I can't provide much info as I can't test the procedure step by step to verify my memories.
Thank you for your reply. It seems it is indeed different between Sony Monitors and TVs. The brightness issue in Monitors is a problem in itself and it doesn't warp the geometry per se. In my problem with the CRT TV it's the geometry that's clearly affected, which in turn can be alleviated via the brightness / screen adjustments. Shame, if the problem was the same all around I would have a better chance of tracking down the failing part that is to blame. If I ever find it out I'll post it in the thread I made
Reply 48979 of 53280, by DerBaum
Predator99 wrote on 2023-04-30, 20:41:
[Dont know what all the LEDs mean.
The LEDs are the same as the display. The LEDs show the binary value and the display shows the converted HEX value.
4 green LED bits and 4 yellow LED bits. each one of these 4 LEDs can show 16 combinations (0-F). Together you have a Byte.
First picture: On(8)/Off(4)/On(2)/On(1) = (8+2+1=11) =B | Off(8)/On(4)/On(2)/On(1) = (4+2+1=7) = 7
FCKGW-RHQQ2
