Reply 500 of 862, by Kamerat
- Oldbie
wrote:wrote:New personal best in Windows 98 SE with 38723 3DMarks, this time with Core 2 Duo E6600 and Asus Radeon X800 XT PCIe. Note that CPU speed detection fails, the real speed is 3776MHz (8x472MHz). 3DMark actually detects the right FSB. No LOD tweaks this time.
Edit: New run, slightly tighter timings.
How did you get the P965 chipset to work with Win98? I never heard of anything higher than 925 working with 98.
Most important is to set the SATA Configuration to Compatible. I'm only using a 80GB SATA drive, so size is not an issue. Also I disabled all onboard devices and all tabs in CPU Configuration. For getting the SB emulation of the Aureal Vortex 8820 to work under MS-DOS, I've reserved IRQ 5 under "Advanced PCI/PnP Settings".
After first step of the Windows install I booted to pure DOS and added MaxPhysPage=20000 under the [386Enh] section in system.ini (Windows will then only see 512MB RAM, it won't even boot when it sees 2GB complaining about insufficient memory).
