Reply 500 of 3175, by shock__
- Oldbie
wrote:* Adapting the audio/joystick ports so standard brackets from donor cards can be used (have we finally confirmed that the sequence of the ports corresponds to the brackets we'll use later?)
Done, don't care about the exact order. Will be Joystick, Out, Mic, Line-In (left to right)
wrote:* Add pinheaders for all audio ports (are they already there and I just can't see them?..)
Not implemented yet
wrote:* Add Waveblaster connector (has this idea been finally abandoned?)
* Add integrated MIF-IPC clone (same as above)
both dropped - that's one of the things the prototype headers are for
wrote:* Make MONOIN and MONOOUT available as pin-headers on the board (marked as PCSPK_IN and PCSPK_OUT) - I still think this could be very nice and useful feature indeed
Can be done
wrote:* Add swappable OPAMPs (I just can't even see if there are any OPAMPs on the card, if there are none, then we don't have anything to swap 😀 )
Haven't dug into that yet - actually haven't even added DIP footprints for the amplifier circuit even.
Current Project: new GUS PnP compatible soundcard
[Z?]
