Reply 500 of 3432, by RaVeN-05
sharangad wrote on 2024-03-01, 22:51:
Thanks! That second Int1A call is very useful. By altering what it returns the error code returned by Speedy3D apps with Verite board not detected changes.
Raven waiting for your results.
Pre-entry (Int 15h)(Call 1) AX 0000, BX BFDE, CX 0008, DX 035F, ES 1592, DI 0006, DS 15CC SI 0000, SP 0FD0, FLAGS 7246
On exit (2) AX 8600, BX BFDE, CX 0008, DX 035F, ES 1592, DI 0006, DS 15CC, SI 0000, SP 0FD0, FLAGS 7A83
Pre-entry (Int 15h)(Call 2) AX 0000, BX BF01, CX 11C0, DX 0011, ES 1592, DI 0006, DS 15CC SI 0000, SP 0FD0, FLAGS 7246
On exit (2) AX 8600, BX BF01, CX 11C0, DX 0011, ES 1592, DI 0006, DS 15CC, SI 0000, SP 0FD0, FLAGS 7A83
Pre-entry (Int 10h)(1) AX 158D, BX 0000, CX 0000, DX 0000, ES 1592, DI 0006, DS 15CC SI 0000, SP 0FD0, FLAGS 7246
On exit (2) AX 0015, BX 0000, CX 0A2C, DX C000, ES 1592, DI 0006, DS 15CC, SI 0000, SP 0FD0, FLAGS 7246
Pre-entry (Int 1ah)(1) AX B101, BX 0000, CX C000, DX 0A2C, ES 1592, DI 0006, DS 15CC SI 0000, SP 0FD0, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX C001, DX 4350, ES 1592, DI 0006, DS 15CC, SI 0000, SP 0FD0, flags 7246
Pre-entry (Int 1ah)(1) AX B102, BX 0000, CX 0001, DX 1163, ES 1592, DI 0006, DS 15CC SI 0000, SP 0FD0, FLAGS 7246
Int 1ah on exit (2) AX 8602, BX 0201, CX 0001, DX 1163, ES 1592, DI 0006, DS 15CC, SI 0000, SP 0FD0, flags 7247
https://www.youtube.com/user/whitemagicraven
https://go.twitch.tv/whitemagicraventv
Reply 501 of 3432, by RaVeN-05
sharangad wrote on 2024-03-01, 23:06:
And once again with a vQuake specific Int 1A call: […]
https://1drv.ms/u/s!As-dKk-N73dSmBMMo-Zu9Ad0nTvO
MD5: 3fa2b0d7f25a64abb05053cbd26814c6
The last few SetModes have been cumulative, when you run a later build it has all the tests of the previous version.
Pre-entry (Int 15h)(Call 1) AX 0000, BX BFDE, CX 0008, DX 035F, ES 159D, DI 0006, DS 15D7 SI 0000, SP 0FD0, FLAGS 7246
On exit (2) AX 8600, BX BFDE, CX 0008, DX 035F, ES 159D, DI 0006, DS 15D7, SI 0000, SP 0FD0, FLAGS 7A83
Pre-entry (Int 15h)(Call 2) AX 0000, BX BF01, CX 11C0, DX 0011, ES 159D, DI 0006, DS 15D7 SI 0000, SP 0FD0, FLAGS 7246
On exit (2) AX 8600, BX BF01, CX 11C0, DX 0011, ES 159D, DI 0006, DS 15D7, SI 0000, SP 0FD0, FLAGS 7A83
Pre-entry (Int 10h)(1) AX 158D, BX 0000, CX 0000, DX 0000, ES 159D, DI 0006, DS 15D7 SI 0000, SP 0FD0, FLAGS 7246
On exit (2) AX 0015, BX 0000, CX 0A2C, DX C000, ES 159D, DI 0006, DS 15D7, SI 0000, SP 0FD0, FLAGS 7246
Pre-entry (Int 1ah)(1) AX B101, BX 0000, CX C000, DX 0A2C, ES 159D, DI 0006, DS 15D7 SI 0000, SP 0FD0, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX C001, DX 4350, ES 159D, DI 0006, DS 15D7, SI 0000, SP 0FD0, flags 7246
Pre-entry (Int 1ah/vQuake) (1) AX B102, BX 0000, CX 0001, DX 1163, ES 159D, DI 0006, DS 15D7 SI 0000, SP 0FD0, FLAGS 7246
Int 1ah on exit (2) AX 8602, BX 0201, CX 0001, DX 1163, ES 159D, DI 0006, DS 15D7, SI 0000, SP 0FD0, flags 7247
Pre-entry (Int 1ah)(1) AX B101, BX 58B8, CX 3246, DX 00A7, ES 159D, DI 0006, DS 15D7 SI 0000, SP 0FD0, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX 3201, DX 4350, ES 159D, DI 0006, DS 15D7, SI 0000, SP 0FD0, flags 7246
Reply 502 of 3432, by Agent of the BSoD
Pre-entry (Int 15h)(Call 1) AX 0000, BX BFDE, CX 0008, DX 035F, ES 0623, DI 0006, DS 065D SI 0000, SP 0FD0, FLAGS 7246
On exit (2) AX 8600, BX BFDE, CX 0008, DX 035F, ES 0623, DI 0006, DS 065D, SI 0000, SP 0FD0, FLAGS 7A83
Pre-entry (Int 15h)(Call 2) AX 0000, BX BF01, CX 11C0, DX 0011, ES 0623, DI 0006, DS 065D SI 0000, SP 0FD0, FLAGS 7246
On exit (2) AX 8600, BX BF01, CX 11C0, DX 0011, ES 0623, DI 0006, DS 065D, SI 0000, SP 0FD0, FLAGS 7A83
Pre-entry (Int 10h)(1) AX 158D, BX 0000, CX 0000, DX 0000, ES 0623, DI 0006, DS 065D SI 0000, SP 0FD0, FLAGS 7246
On exit (2) AX 0015, BX 0000, CX 09FC, DX C000, ES 0623, DI 0006, DS 065D, SI 0000, SP 0FD0, FLAGS 7246
Pre-entry (Int 1ah)(1) AX B101, BX 0000, CX C000, DX 09FC, ES 0623, DI 0006, DS 065D SI 0000, SP 0FD0, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX C002, DX 4350, ES 0623, DI 0006, DS 065D, SI 0000, SP 0FD0, flags 7246
Pre-entry (Int 1ah/vQuake) (1) AX B102, BX 0000, CX 0001, DX 1163, ES 0623, DI 0006, DS 065D SI 0000, SP 0FD0, FLAGS 7246
Int 1ah on exit (2) AX 0002, BX 0040, CX 0001, DX 1163, ES 0623, DI 0006, DS 065D, SI 0000, SP 0FD0, flags 7246
Pre-entry (Int 1ah)(1) AX B101, BX 58B8, CX 3246, DX 00A7, ES 0623, DI 0006, DS 065D SI 0000, SP 0FD0, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX 3202, DX 4350, ES 0623, DI 0006, DS 065D, SI 0000, SP 0FD0, flags 7246
Pentium MMX 233 | 64MB | FIC PA-2013 | Matrox Mystique 220 | SB Pro 2 | Music Quest MPU Clone | Windows 95B
MT-32 | SC-55mkII, 88Pro, 8820 | SB16 CT2230
3DFX Voodoo 1&2 | S3 ViRGE GX2 | PowerVR PCX1&2 | Rendition Vérité V1000 | ATI 3D Rage Pro
Reply 503 of 3432, by sharangad
Every single DOS game seems to have it's own set of Int1A (AX=0xB101) calls. Every single one's different. DMA test is the only one which passes a video BIOS address. Not sure whether this is related to paging.
https://patreon.com/Rready
Reply 504 of 3432, by sharangad
Yup every single card returns a different set of values. Just to check it would be nice if Demonized999 tested his card. His board has a non-reference BIOS with a slightly different address.
Reply 506 of 3432, by Agent of the BSoD
Well, I got a copy of F1 of what I thought was the right CD. Apparently not. This copy only supports the Rage Pro, which from what I'm reading was probably bundled with card itself. So I'm back to not being sure what disc to look for.
Reply 508 of 3432, by sharangad
Agent it would be useful to see if the F1 wrapper works with stock drivers on a V1000.
Usually f1red.exe needs rredline 1.0 drivers to run on a V1000.
Reply 509 of 3432, by sharangad
Apologies for the delay:
https://1drv.ms/u/s!As-dKk-N73dSmBQMo-Zu9Ad0nTvO
MD5: c389d035b5e8c3eac4e09867b1c0f19a
This should log Int 1A calls for all the DOS games that I have.
Reply 510 of 3432, by RaVeN-05
Pre-entry (Int 15h)(Call 1) AX 0000, BX BFDE, CX 0008, DX 035F, ES 15C8, DI 0006, DS 1602 SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 8600, BX BFDE, CX 0008, DX 035F, ES 15C8, DI 0006, DS 1602, SI 0000, SP 0FD4, FLAGS 7A83
Pre-entry (Int 15h)(Call 2) AX 0000, BX BF01, CX 11C0, DX 0011, ES 15C8, DI 0006, DS 1602 SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 8600, BX BF01, CX 11C0, DX 0011, ES 15C8, DI 0006, DS 1602, SI 0000, SP 0FD4, FLAGS 7A83
Pre-entry (Int 10h)(1) AX 158D, BX 0000, CX 0000, DX 0000, ES 15C8, DI 0006, DS 1602 SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 0015, BX 0000, CX 0A2C, DX C000, ES 15C8, DI 0006, DS 1602, SI 0000, SP 0FD4, FLAGS 7246
Pre-entry (Int 1ah)(1) AX B101, BX 0000, CX C000, DX 0A2C, ES 15C8, DI 0006, DS 1602 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX C001, DX 4350, ES 15C8, DI 0006, DS 1602, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/vQuake) (1) AX B102, BX 0000, CX 0001, DX 1163, ES 15C8, DI 0006, DS 1602 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 8602, BX 0201, CX 0001, DX 1163, ES 15C8, DI 0006, DS 1602, SI 0000, SP 0FD4, flags 7247
Pre-entry (Int 1ah)(1) AX B101, BX 58B8, CX 3246, DX 00A7, ES 15C8, DI 0006, DS 1602 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX 3201, DX 4350, ES 15C8, DI 0006, DS 1602, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/Fatal Racing)(1) AX B101, BX 9F38, CX 6904, DX 0000, ES 15C8, DI 0006, DS 1602 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX 6901, DX 4350, ES 15C8, DI 0006, DS 1602, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/Indy Car Racing II)(1) AX B101, BX EED4, CX 2324, DX 0000, ES 15C8, DI 0006, DS 1602 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX 2301, DX 4350, ES 15C8, DI 0006, DS 1602, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/Nascar 1999 Rendition)(1) AX B108, BX 0040, CX C000, DX 0A3C, ES 15C8, DI 0006, DS 1602 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0040, CX C0FF, DX 0A3C, ES 15C8, DI 0006, DS 1602, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/SPlanet)(1) AX B108, BX 0000, CX 0000, DX 0000, ES 15C8, DI 0006, DS 1602 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0000, CX 0010, DX 0000, ES 15C8, DI 0006, DS 1602, SI 0000, SP 0FD4, flags 7246
Reply 512 of 3432, by sharangad
And one more:
https://1drv.ms/u/s!As-dKk-N73dSmBYMo-Zu9Ad0nTvO
MD5: 8511edca87f0d7f208d3c457721d4cc3
If this produces the results I expect, there'll be a lot more SetModes to come and I mean a lot.
Reply 513 of 3432, by RaVeN-05
Pre-entry (Int 15h)(Call 1) AX 0000, BX BFDE, CX 0008, DX 035F, ES 15E9, DI 0006, DS 1623 SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 8600, BX BFDE, CX 0008, DX 035F, ES 15E9, DI 0006, DS 1623, SI 0000, SP 0FD4, FLAGS 7A83
Pre-entry (Int 15h)(Call 2) AX 0000, BX BF01, CX 11C0, DX 0011, ES 15E9, DI 0006, DS 1623 SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 8600, BX BF01, CX 11C0, DX 0011, ES 15E9, DI 0006, DS 1623, SI 0000, SP 0FD4, FLAGS 7A83
Pre-entry (Int 10h)(1) AX 158D, BX 0000, CX 0000, DX 0000, ES 15E9, DI 0006, DS 1623 SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 0015, BX 0000, CX 0A2C, DX C000, ES 15E9, DI 0006, DS 1623, SI 0000, SP 0FD4, FLAGS 7246
Rendition Segment 0000C000, Rendition Base 00000A2C
Pre-entry (Int 1ah)(1) AX B101, BX 0000, CX C000, DX 0A2C, ES 15E9, DI 0006, DS 1623 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX C001, DX 4350, ES 15E9, DI 0006, DS 1623, SI 0000, SP 0FD4, flags 7246
Searching for Rendition Verite V1000
Pre-entry (Int 1ah/vQuake) (1) AX B102, BX 0000, CX 0001, DX 1163, ES 15E9, DI 0006, DS 1623 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 8602, BX 0201, CX 0001, DX 1163, ES 15E9, DI 0006, DS 1623, SI 0000, SP 0FD4, flags 7247
Found V1000 bus # 2, dev num 1
Pre-entry (Int 1ah)(1) AX B101, BX 58B8, CX 3246, DX 00A7, ES 15E9, DI 0006, DS 1623 SI 0000, SP 0FD4, FLAGS 7216
Int 1ah on exit (2) AX 0011, BX 0210, CX 3201, DX 4350, ES 15E9, DI 0006, DS 1623, SI 0000, SP 0FD4, flags 7216
Pre-entry (Int 1ah/Fatal Racing)(1) AX B101, BX 9F38, CX 6904, DX 0000, ES 15E9, DI 0006, DS 1623 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX 6901, DX 4350, ES 15E9, DI 0006, DS 1623, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/Indy Car Racing II)(1) AX B101, BX EED4, CX 2324, DX 0000, ES 15E9, DI 0006, DS 1623 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX 2301, DX 4350, ES 15E9, DI 0006, DS 1623, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/SPlanet)(1) AX B102, BX 0000, CX 0001, DX 1163, ES 15E9, DI 0006, DS 1623 SI 0000, SP 0FD4, FLAGS 7246
Pre-entry (Int 1ah/Nascar 1999 Rendition)(1) AX B108, BX 0040, CX C000, DX 0A3C, ES 15E9, DI 0006, DS 1623 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0040, CX C0FF, DX 0A3C, ES 15E9, DI 0006, DS 1623, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/SPlanet)(1) AX B108, BX 0000, CX 0000, DX 0000, ES 15E9, DI 0006, DS 1623 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0000, CX 0010, DX 0000, ES 15E9, DI 0006, DS 1623, SI 0000, SP 0FD4, flags 7246
Reply 515 of 3432, by RaVeN-05
Not found
Searching for Rendition Verite V2000
Pre-entry (Int 1ah/vQuake) (1) AX B102, BX 0000, CX 2000, DX 1163, ES 15E9, DI 0006, DS 1623 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0002, BX 0100, CX 2000, DX 1163, ES 15E9, DI 0006, DS 1623, SI 0000, SP 0FD4, flags 7246
Found V2000 bus # 1, dev num 0
Reply 516 of 3432, by Agent of the BSoD
Pre-entry (Int 15h)(Call 1) AX 0000, BX BFDE, CX 0008, DX 035F, ES 0670, DI 0006, DS 06AA SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 8600, BX BFDE, CX 0008, DX 035F, ES 0670, DI 0006, DS 06AA, SI 0000, SP 0FD4, FLAGS 7A83
Pre-entry (Int 15h)(Call 2) AX 0000, BX BF01, CX 11C0, DX 0011, ES 0670, DI 0006, DS 06AA SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 8600, BX BF01, CX 11C0, DX 0011, ES 0670, DI 0006, DS 06AA, SI 0000, SP 0FD4, FLAGS 7A83
Pre-entry (Int 10h)(1) AX 158D, BX 0000, CX 0000, DX 0000, ES 0670, DI 0006, DS 06AA SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 0015, BX 0000, CX 09FC, DX C000, ES 0670, DI 0006, DS 06AA, SI 0000, SP 0FD4, FLAGS 7246
Rendition Segment 0000C000, Rendition Base 000009FC
Pre-entry (Int 1ah)(1) AX B101, BX 0000, CX C000, DX 09FC, ES 0670, DI 0006, DS 06AA SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX C002, DX 4350, ES 0670, DI 0006, DS 06AA, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/vQuake) (1) AX B102, BX 0000, CX 0001, DX 1163, ES 0670, DI 0006, DS 06AA SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0002, BX 0040, CX 0001, DX 1163, ES 0670, DI 0006, DS 06AA, SI 0000, SP 0FD4, flags 7246
Found V1000 bus # 0, dev num 64
Pre-entry (Int 1ah)(1) AX B101, BX 58B8, CX 3246, DX 00A7, ES 0670, DI 0006, DS 06AA SI 0000, SP 0FD4, FLAGS 7216
Int 1ah on exit (2) AX 0011, BX 0210, CX 3202, DX 4350, ES 0670, DI 0006, DS 06AA, SI 0000, SP 0FD4, flags 7216
Pre-entry (Int 1ah/Fatal Racing)(1) AX B101, BX 9F38, CX 6904, DX 0000, ES 0670, DI 0006, DS 06AA SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX 6902, DX 4350, ES 0670, DI 0006, DS 06AA, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/Indy Car Racing II)(1) AX B101, BX EED4, CX 2324, DX 0000, ES 0670, DI 0006, DS 06AA SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX 2302, DX 4350, ES 0670, DI 0006, DS 06AA, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/SPlanet)(1) AX B102, BX 0000, CX 0001, DX 1163, ES 0670, DI 0006, DS 06AA SI 0000, SP 0FD4, FLAGS 7246
Pre-entry (Int 1ah/Nascar 1999 Rendition)(1) AX B108, BX 0040, CX C000, DX 0A3C, ES 0670, DI 0006, DS 06AA SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0040, CX C080, DX 0A3C, ES 0670, DI 0006, DS 06AA, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/SPlanet)(1) AX B108, BX 0000, CX 0000, DX 0000, ES 0670, DI 0006, DS 06AA SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0000, CX 0090, DX 0000, ES 0670, DI 0006, DS 06AA, SI 0000, SP 0FD4, flags 7246
Reply 519 of 3432, by Agent of the BSoD
Pre-entry (Int 15h)(Call 1) AX 0000, BX BFDE, CX 0008, DX 035F, ES 066D, DI 0006, DS 06A7 SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 8600, BX BFDE, CX 0008, DX 035F, ES 066D, DI 0006, DS 06A7, SI 0000, SP 0FD4, FLAGS 7A83
Pre-entry (Int 15h)(Call 2) AX 0000, BX BF01, CX 11C0, DX 0011, ES 066D, DI 0006, DS 06A7 SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 8600, BX BF01, CX 11C0, DX 0011, ES 066D, DI 0006, DS 06A7, SI 0000, SP 0FD4, FLAGS 7A83
Pre-entry (Int 10h)(1) AX 158D, BX 0000, CX 0000, DX 0000, ES 066D, DI 0006, DS 06A7 SI 0000, SP 0FD4, FLAGS 7246
On exit (2) AX 0015, BX 0000, CX 09FC, DX C000, ES 066D, DI 0006, DS 06A7, SI 0000, SP 0FD4, FLAGS 7246
Pre-entry (Int 1ah)(1) AX B101, BX 0000, CX C000, DX 09FC, ES 066D, DI 0006, DS 06A7 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0011, BX 0210, CX C002, DX 4350, ES 066D, DI 0006, DS 06A7, SI 0000, SP 0FD4, flags 7246
Pre-entry (Int 1ah/vQuake) (1) AX B102, BX 0000, CX 0001, DX 1163, ES 066D, DI 0006, DS 06A7 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0002, BX 0040, CX 0001, DX 1163, ES 066D, DI 0006, DS 06A7, SI 0000, SP 0FD4, flags 7246
Pre-entry (Register read) (1) AX B108, BX 0040, CX 0000, DX 0000, ES 066D, DI 000B, DS 06A7 SI 0000, SP 0FD4, FLAGS 7216
Int 1ah on exit (2) AX 0008, BX 0040, CX 0003, DX 0000, ES 066D, DI 000B, DS 06A7, SI 0000, SP 0FD4, flags 7216
Read register[000B] = 03*****************************************************************************
Pre-entry (Register read) (1) AX B108, BX 0040, CX 06A7, DX 0000, ES 066D, DI 0013, DS 06A7 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0040, CX 06E1, DX 0000, ES 066D, DI 0013, DS 06A7, SI 0000, SP 0FD4, flags 7246
Read register[0013] = E1*****************************************************************************
Pre-entry (Register read) (1) AX B108, BX 0040, CX 06A7, DX 0000, ES 066D, DI 0015, DS 06A7 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0040, CX 06E8, DX 0000, ES 066D, DI 0015, DS 06A7, SI 0000, SP 0FD4, flags 7246
Read register[0015] = E8*****************************************************************************
Pre-entry (Register read) (1) AX B108, BX 0040, CX 06A7, DX 0000, ES 066D, DI 003C, DS 06A7 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0040, CX 060A, DX 0000, ES 066D, DI 003C, DS 06A7, SI 0000, SP 0FD4, flags 7246
Read register[003C] = 0A*****************************************************************************
Pre-entry (Register read) (1) AX B108, BX 0040, CX 06A7, DX 0000, ES 066D, DI 0004, DS 06A7 SI 0000, SP 0FD4, FLAGS 7246
Int 1ah on exit (2) AX 0008, BX 0040, CX 0607, DX 0000, ES 066D, DI 0004, DS 06A7, SI 0000, SP 0FD4, flags 7246
Read register[0004] = 07*****************************************************************************
