Reply 50640 of 53128, by pete8475
misterjones wrote on 2023-10-14, 19:18:
Found this at a local thrift shop yesterday. Still shrink wrapped and everything. […]
Send in that rebate card! Please!!!!
Reply 50641 of 53128, by Meatball
Added an MX400, MX420 PCI, and GeForce2 Ultra to the collection. All are 64MB/128-bit cards. The MX420 has 4.5ns RAM, and it clocks up to 233MHz before blowing out. The default clock of 166MHz really holds this card back. Without adjusting the core, 3DMark 2000 scores improved from about 5400 to 6600. Boosting the core to 280MHz provides the ability for basically free 2x Aniso. The score was about 6500. The Ultra clock goes to 290MHz without any problems, and I didn't push it any further.
The RAM is 4ns, but I can only get it to 247MHz for artifact-free performance. 250MHz shows just a bit of pixel flicker and by 260MHz, I'm basically getting scanlines.
Reply 50642 of 53128, by Horun
mrfusion92 wrote on 2023-10-14, 07:49:
My frenzy for subnotebooks strikes again.
Bought an HP Omnibook 800CT with full gear of accessory (external floppy and cdrom) and original boxes from original owner.
All for 30€ because the laptop shows only a white screen. But it actually boots, because Windows sounds can be heard. So I'm hoping it is just a dodgy cable inside.
Nice ! I think that external cdrom is a Panasonic (looks near similar to my Pana 4x scsi for my Toshiba 110cs, left end of the cable looks like same micro scsi of that era). That alone is worth the money if it works....
Mine has the PCMCIA scsi card too so can use it on other non-cd older lappy's. Good find and hope you get the 800ct working !
Reply 50643 of 53128, by Horun
appiah4 wrote on 2023-10-14, 19:29:
I got these two in return for a trade where I gave away a high end Socket 754 PC and a 3dfx video card. I think it was a fair trade, and I hope to have a dual Socket 8 motherboard for these some day. Currently I own only a single single socket Socket 8 motherboard, which is a shame. I'd love to try NT 4.0 with these.
Nice ! am always a sucker for Pentium Pro's and those are 512k versions.
Reply 50644 of 53128, by PcBytes
Latitude C600.
Was in worse shape than what you're seeing...
Specs:
P3 1GHz (Coppermine likely)
Rage Mobility 128 8MB (not bad I guess)
440BX
40GB HDD (Samsung)
originally had XP, wiped and installed 2k Pro SP4.
Also one of those goofy JNC-Nokia styled cases, out of which an A64 3000+ and a Geforce 6600GT came out of.
Reply 50645 of 53128, by Brawndo
What a cool find! I remember back in the day wanting an Xpert@Play 98, don't recall if I ever got one.
Reply 50646 of 53128, by 3lectr1c
@PcBytes - Here's your obligated warning that the C600 has a VARTA NiMH CMOS battery located directly on top of the motherboard, under the keyboard. Get it out before your C600 is destroyed!
I probably have too many old laptops.
Reply 50647 of 53128, by Kahenraz
3lectr1c wrote on 2023-10-16, 02:14:
Sometimes it doesn't even need to be a direct leak. I had a Sony Vaio laptop ruiend from the corrosion creeping all the way down the CMOS battery wire, onto the power supply circuit, where it ate into and destroyed it.
Reply 50648 of 53128, by PcBytes
It hasn't leaked yet... and I found it near the RAM slots, not the top of the mobo. I think it was the C610 that it had it under the keyboard?
Speaking of which... maybe I can use the CMOS battery in the C600 to revive the 610? The 610 wouldn't detect HDDs no matter what though I remember the VARTA battery missing and someone here did suggest it could be due to it.
Reply 50649 of 53128, by 3lectr1c
Ah, I was not aware that the C600 had it in a different location. I've heard that someone had it destroy their system, so the difference in location doesn't mean it's safe in this case.
I've only seen firsthand the C610 and the C640.
@PcBytes - the C610 doesn't need the battery installed for it to detect drives. Mine has had it removed for many years now and it's fine. Yours must be some other fault unfortunately.
I wouldn't put the C600's battery back in any computer at all. It's just not safe now given their age.
Reply 50650 of 53128, by thp
New in-box ESS Solo-1 (TerraTec 128i PCI) obtained for really cheap a few weeks ago. Unfortunately, despite all the good things said about its DOS compatibility (and ESFM working fine), I couldn't get its PCM output working reliably on the machine I bought it for, and ended up implementing SBEMU support for its on-board (SIS7012) sound chip instead, which - despite the software overhead - seems to work much more reliably than the Solo-1, so that machine isn't in need of that PCI sound card anymore. On Linux, both PCM and FM are fine, so the card works perfectly fine.
    261.36 KiB
    TerraTec 128i PCI
Reply 50651 of 53128, by stef80
@thp
May be due to version of the card? This is the most equipped one:
https://www.phc.sk/resize/e/800/800/files/imp … o-1-500x500.jpg
More:
https://www.pc-schnulli.de/hardw/skpci/trskpci.html
Reply 50652 of 53128, by acl
thp wrote on 2023-10-17, 05:41:
Very surprising box art.
Was that creepy deep sea fish supposed to convince me to buy this sound card ?
Reply 50653 of 53128, by Grzyb
acl wrote on 2023-10-17, 07:22:
Fish are silent, so it perfectly matches a sound card with dysfunctional PCM 🤣
Nie tylko, jak widzicie, w tym trudność, że nie zdołacie wejść na moją górę, lecz i w tym, że ja do was cały zejść nie mogę, gdyż schodząc, gubię po drodze to, co miałem donieść.
Reply 50654 of 53128, by thp
Even more curious, at the back of the box in the lower left corner it says "Did you know? - The latin name for the fish on the front is ANOPLOGASTER CORNUTA", so it seems like TerraTec's marketing team was at least self-aware that they were putting fish art onto the front of the box.
Reply 50655 of 53128, by Kahenraz
These cards are generally very compatible, but I have also had the odd occasion where they didn't work. It's rare, but it does happen. It has to do with chipset incompatibility with how they are routing DMA over the PCI bus, I believe.
Here are instructions on how to use ESS drivers, along with the latest versions:
Guide for configuring ESS PCI Audio cards for DOS (Solo, Maestro, Allegro, etc.)
Note that these cards need to be configured from within Windows. You cannot just copy an INI file over from another machine, since it sets itself up based on what feature for DMA is most compatible with the hardware of your machine.
Reply 50656 of 53128, by RetroPC_King
Today I got those!
-2 PCI risers (PCI-X or 64bit PCI maybe, I don't know)
-Trendnet Realtek RTL8139D PCI 10/100 network card
Any opinions?
Reply 50657 of 53128, by weedeewee
RetroPC_King wrote on 2023-10-17, 18:13:
Today I got those! […]
Today I got those!
Any opinions?
1- Those tends to be very mainboard/brand specific
2- very generic card.
Do not ask Why !
Reply 50658 of 53128, by BitWrangler
Usually if the contact count on the bottom is the same as on the socket you are okay. If the slots are positioned different or there seems to be a lot more than decoupling capacitors on the board, then YMMV.
Reply 50659 of 53128, by acl
Grzyb wrote on 2023-10-17, 07:53:
😄 But it works on Linux so the fish is not always silent.
(I personally consider Linux sound to be a total mess. ALSA, PulseAudio, PipeWire... )
thp wrote on 2023-10-17, 07:59:
They take their job very seriously 😁
I googled a bit and i could not find any other Terratec package featuring animals.
