Post pics of your CRT monitors
Reply 520 of 544, by Kalle
Medion MD1772JC, got it as a replacement for the hp 72 which couldn't be repaired. So far it's working well and the image looks nice 😀
160 KiB
200.83 KiB
130.22 KiB
Reply 521 of 544, by Intel486dx33
My 199o's Home lab.
I started out with a 486 computer and it never stopped growing.
    15.57 KiB
    330.67 KiB
Reply 522 of 544, by theelf
bjwil1991 wrote on 2023-01-01, 09:21:
https://i.imgur.com/xbl3WKll.png […]
KFC 15” VGA (coming soon, just purchased on eBay)
Orion TVCR0950B
Hi, waiting the pictures of the kfc! thanks
Reply 523 of 544, by bjwil1991
Ask and ye shall receive. Connected to my main gaming rig via HDMI to VGA adapter. However, I need to source a better adapter and fix the cabling since the picture has a slight pink tint due to the cable not being entirely flush with the converter adapter.
528.17 KiB
I also connected it to my VHS/Blu-Ray combo the other day and once I connect my speakers, I'll definitely will watch movies on this.
Reply 524 of 544, by arncht
I got this display. Eizo 9070s from 1988.
    151.06 KiB
    463.23 KiB
    568.6 KiB
    677.62 KiB
Overdoze of the demoscene
Reply 525 of 544, by vutt
From slightly diffrent angle - my "new" Sony Trinitron CPD-E100 😀
It is working. Bulit November 2000, cost me 5€ + 20 year dust layer for free. Good deal I think...
    333.7 KiB
Reply 526 of 544, by Demetrio
1.6 MiB
NEC MultiSync V720
1.72 MiB
My P1 MMX build CRT - Don't know the model
203.61 KiB
IBM G40 - My favourite
Reply 527 of 544, by RockmanZ3R0
Jed118 wrote on 2018-02-10, 19:33:
1992's TTX XGA (I got it to 1280x1024) - Not sure of the dot pitch but it is kinda blurry and changing the resolution bounces th […]
1992's TTX XGA (I got it to 1280x1024) - Not sure of the dot pitch but it is kinda blurry and changing the resolution bounces the image around. I've relegated it to my 286 (which really needs an EGA)
This Samsung Syncmaster 3Ne for my 486 DX2/66 - Very clear and sharp image. I occasionally will use it for Photoshop work:
And 1989's DataTrain DC-509 VGA monitor that came with my 386SX. I have the original packaging and styrofoam for this one.
Decently clear image for what it is.
I also have an NCR 17 inch in the closet, a 14" Digital XGA and another 17" TTX in original packaging that I will try to bundle with a PII system when I'm ready to sell it.
Unsure if you care or not at this point but I used to have that same monitor as a kid and just recently found the old parts list from the computer it went with from the store, it claims it is ".39 dot pitch S-VGA"
Reply 529 of 544, by chrismeyer6
Lodge_ wrote on 2023-06-14, 10:26:
I just saved this really nice ViewSonic E70 from being thrown in the trash. It's from 2006 so basically it's brand new! […]
That's an excellent save. Being so new it should have a decent amount of life left in the tube. How's the picture quality of it?
Reply 530 of 544, by Lodge_
chrismeyer6 wrote on 2023-06-14, 11:34:
Just perfect for my Windows 95 setup! The difference between Dell 1703FP and this with lower resolutions is like night and day. The picture is so crisp.
Reply 532 of 544, by Turmion
I only have two decent CRTs, the rest are meh compared to these. First is a weird Iiyama, weird in the sense that it has no manual or specs that can be found, it isn't that special but has a nice mid-late 90s aesthetic while being 20 inches viewable and 1600x1200 @70hz although it ran 1600x1200 @85hz on my 3870x2, not sure why it wouldn't 'support' that higher refresh rate on my 4870, I'm quite noob at crts.
272.46 KiB
GPL-2.0-or-later
556.95 KiB
GPL-2.0-or-later
The second is a 230sb, from what i can tell its slightly lower end than a 2070sb that gets talked about much more often, I use this quite regularly for modern games via usb c to vga (sadly can only do 1280x1024 @85hz but its enough for me).
154.14 KiB
GPL-2.0-or-later
456.7 KiB
GPL-2.0-or-later
Reply 533 of 544, by Mandrew
I had to pick up a faulty hercules monochrome with possible cold solder joints in the deflection circuit, love these generic Taiwanese monochrome clones.
I was hoping for an amber type but it's the white phosphor variant. Whatever, worth a shot at repairing it.
Reply 534 of 544, by Jed118
RockmanZ3R0 wrote on 2023-06-12, 21:33:
Oh myyyyyyyyyyyyyyyyy that's worse than I recall.
What's for sale? my eBay!
Reply 535 of 544, by copper
Micron 900MX acquired at the town recycling day. Apparently it's a rebranded CTX PR960F, 2001 vintage.
19" Trinitron tube.
Reply 536 of 544, by mgtroyas
Back on the early 2000s I had a white 17 inch Philips monitor (107E). So for nostalgia I got a sleek black 17 inch, same tube but slightly more compact model than mine (107E5), I already saw them back in the day on my college and thought they were cool.
Nothing special, it reaches 1280x1024@60Hz, the intended resolution is 1024x768@85 but I always use it al 1152x864@75, I love the resulting slightly softened image, like a hardware based free antialiasing.
It's capable of 640x480@120, rock solid lag free refresh, which is perfect for emulating any old console with frame doubling, or lagless retro PC gaming. I don't have a high refresh rate LCD, but playing a FPS at 120 Hz on a CRT is something otherwordly, the connection between mouse movement and image movement is extremely instant and smooth, specially using a high DPI and USB poll rate mouse (Logitech G203).
It's black because it matches the overpowered small form factor XP gaming rig I've built for late-98/XP/early-Vista gaming, a Dell Optiplex 7010 with Ivy Bridge CPU and a passively cooled DDR5 Geforce GT730 (with VGA output).
I have it connected to both the Optiplex and my modern Windows 11 machine with a KVM , it's fun to compare on same period-correct display between older more compatible OS and modern wrappers.
Reply 537 of 544, by buckeye
Recently got this 17" NEC Accusync 700 NIB off ebay. This is not my 1st attempt at getting a workable CRT as shipping adventures
and just plain worn out models are the norm it seems. No trinitron here but it's bright and clear for my needs. Does up to 1280 X 1024
at 60hz and with a 0.27 dot pitch however this is mainly used for win98/dos so it's good.
Intel SE440BX P3 450 256MB 80GB SSD Asus V7700 GF2 64mb SB 32pnp 350W 98SE
Reply 538 of 544, by Intel486dx33
This was my first computer 486dx-33 mini tower with a 14-inch Non-interlaced SVGA color monitor back in 1993
And one of the first Laser printers by Ricoh.
    211.2 KiB
Reply 539 of 544, by Kalle
Recently I got a Samsung SyncMaster 750p for free as it had a problem, it would only show a white screen. The cause was a failed inductor, now with a new one it works nicely 😀
    270.61 KiB
    322.18 KiB
    436.22 KiB
