Reply 5200 of 60074, by Blurredman
Skyscraper wrote:
This beautie. New in Box. ~23 Euro buyout. Also included 2x550 MHz P3 550 (used), Unspecified amount of memory (used). […]
Seems someone planned a build a long time ago...
How much RAM can that baby take? I'm taking a wild guess at 2gb??
kithylin wrote:
$6.50 off ebay, works fine. No performance tests yet, just basic functionality tests. Popped it in my AMD K6-III/550 machine, ca […]
$6.50 off ebay, works fine. No performance tests yet, just basic functionality tests. Popped it in my AMD K6-III/550 machine, came on fine and went through some basic dos test software just fine, even ran a color palette test and it went fine.
That vga connector is a little rusty. Where's it been stored, under the sea? 😀
http://blurredmanswebsite.ddns.net/ 😊
Reply 5201 of 60074, by nforce4max
Good deal on that ET6000, just clean the connector and you are set.
Reply 5202 of 60074, by kithylin
Blurredman wrote:
<snip>
No idea, but I don't care. It was cheap and it works perfectly fine.
It's just surface rust, I can probably clean it with a little sand paper later.
Reply 5203 of 60074, by Blurredman
It's no big deal, but I often wonder how that happens. Fair enough I sometimes suck the end of my USB stick, but I don't suck the VGA port on my graphics card.
Reply 5204 of 60074, by Lukeno94
Low-quality metal and a fairly humid room don't always mix well.
Reply 5205 of 60074, by Unknown_K
Do the Tseng ET-6000's run faster with 4 RAM chips? Anybody ever see those upgrade chips loose?
Reply 5206 of 60074, by smeezekitty
Reply 5207 of 60074, by Artex
Hahah. Glad I'm not the only one that saw that 'out of context.'
Reply 5208 of 60074, by Artex
4 x 3DFX Voodoo3 3500 5.5ns 183mhz 16MB AGP (1999)
A little upgrade for my 'workhorse' HP DC7800 tower...
Intel Core 2 Quad Q9550 2.83GHz 12MB 1333MHz Socket LGA 775 SLAWQ (2008)
NVIDIA GeForce2 GTS - Hercules 3D Prophet II GTS 32MB AGP (NV15) (NOS) (2000)
Gravis GamePad Pro (NOS) (1998)
Intel i740 - Real3D StarFighter SFP-136 16MB PCI (1998)
Reply 5209 of 60074, by Skyscraper
Blurredman wrote:
Skyscraper wrote:
http://u.cubeupload.com/jonaz81a/SupermicroP6DGE.jpg […]
Yes max is 2 GB but I am not sure if I need ECC memory if I go over 1GB or if 4 normal 512mb modules will work.
The card is still at the post office but I will pick it up tomorrow if I get home early enough.
And for those who had questions about what OS this system will run, it will run Windows 2000.
When it comes to CPUs I will probably see if I can get a couple of Coppermine 1000@750+ CPUs on slotkets to play nice.
The board does have a hidden 133 MHz FSB option but I doubt it is stable.
Reply 5210 of 60074, by ODwilly
Hey Artex, Iv got one of those Gravis Gamepads, how good are they and what games are good to play with it? I used to play Midtown Madness and Motocross madness with it as a kid, but those are the only kind of games I can imagine playing with it.
Reply 5211 of 60074, by Artex
These controllers are very basic... And I mean VERY. No fancy schmancy vibration or anything else that current controllers have. BUT, it definitely beat using the keyboard for platformers like Commander Keen, Jazz Jackrabbit, etc. It was also ok for fighting games like Rise of the Robots, Mortal Kombat, etc. For racing games I actually preferred using the keyboard... But that's just me. 😀
Reply 5212 of 60074, by AidanExamineer
Oof, racing games with a keyboard are so spastic! Guess it's not much better with a digital controller.
So how about a Namco Jogcon?
Reply 5213 of 60074, by Lukeno94
Some racing games play fine with a keyboard; the "ricer" era Need for Speed games, for example, are no better with a wheel than they are with a keyboard. You definitely can't play a racing sim properly without a wheel though.
Reply 5214 of 60074, by rick6
Got this odd Geforce 3 ti200 64mb.
file.php?mode=view&id=15947&sid=e1acf41851beeb383f1eda77d6fdd77d
Punny little cooler which should justify why it has by default lower clocks than a standard Gf3 ti200.
Works perfectly fine nonetheless.
My 2001 gaming beast in all it's "Pentium 4 Williamate" Glory!
Reply 5215 of 60074, by SquallStrife
Going tomorrow to pick up an IBM 5151 monitor. Finally!!!!!!!!
Reply 5216 of 60074, by sliderider
[quote="Artex"]4 x 3DFX Voodoo3 3500 5.5ns 183mhz 16MB AGP (1999)
You do know those Compaq V3 3500's without the TV tuner are pretty common right? There's a seller on ebay who's had hundreds of them for sale for a few years now. There's not a lot of reason to hoard those.
Reply 5217 of 60074, by Artex
Yup, got em for $10 each.
Reply 5218 of 60074, by joacim
I've only ever seen 3500s with the TV tuner on ebay. When I search now I only see ones with the TV tuner and missing the blue cable/box.
Got any links?
Reply 5219 of 60074, by Artex
Got any links?
Here's where I got mine:
http://www.ebay.com/itm/147286-001-147908-001 … =item27b06841ee
Kind of a generic search, but the keyword "Compaq" is key as it denotes the 5.5ns / 183Mhz Compaq OEM cards. You can see the Compaq sticker on these.
